Broker down DL1000
Topic: Broker down DL1000 (Read 1058 times)
robgoc72
Bike: DL1000 K4
Broker down DL1000
June 05, 2022, 10:29:17 »
hi. I'm going from Poland to Montenegro. my vstrom broke down in Bratislava. battery not charging. Can anyone help?
Fat Rat
Administrator
Bloke/Geezer/Fella
Re: Broker down DL1000
June 05, 2022, 10:32:32 »
Do you have tools, a Multimeter?
Bikers Campsite in West Wales
Visit the
V-Strom.co.uk shop
today!
MartinW
Administrator
Bike: DL650 K4 Blue
June 05, 2022, 10:44:09 »
Check your Kill Switch?
If you're sure the battery isn't charging then I guess you are past that stage, but they do catch people out.
Barbel Mick
Bike: 800RE
June 05, 2022, 11:06:27 »
Have you tested the charging on the bike or is it that you just have a flat battery?
You need to check the charging circuit, around 13.8 + volts at 3000rpm. If you're getting that then it's probably just a flat (or maybe faulty) battery.
If it's not charging then possibly a faulty regulator/rectifier or stator.
I also believe there is a problem with the magnets coming loose on the flywheel of that year bike?
Upt North
Bike: DL650 L7
June 05, 2022, 12:56:52 »
A new battery has got to be worth a try. They do sometimes fail badly. How old is it, have you checked the battery leads, earths etc.
Beyond that I see a tow in your future.
Upt'North.
pichulec
Bike: KTM 1290 SAS
Reply #5 on:
June 05, 2022, 14:45:22 »
Unfortunately in this model the common fault is faulty stator. I hope this is not the case, but if it is then it will be costly and time consuming repair, considering you are abroad. New battery for a start would be good idea.
Upt North
Bike: DL650 L7
Reply #6 on:
June 05, 2022, 14:58:16 »
If it'll start off a jump or a boost, try that.
Does the charge light go out?
Can you check what voltage is going across the battery at that stage, once running. I would have thought it'd be around 14V.
Upt'North.
Gert
Reply #7 on:
June 06, 2022, 07:52:33 »
If the above advice doesn't solve the charging problem, then it may be worth having a look at the stator magnets. Chances are that you may require a new gasket after opening the stator cover.
Many first gen Vee owners have reported on stator magnet migration. The solution to repair this stator migration,
https://www.stromtrooper.com/threads/stator-magnets-jb-weld-pictures.400946/
The same stator migration was also reported by various SV owners,
https://www.sv-portal.com/forums/5-tweaking-tuning-tricking/43261-magneto-magnet-repair-diy.html
pichulec
Bike: KTM 1290 SAS
Reply #8 on:
June 06, 2022, 20:01:49 »
I have essentially DL1000 K5 and when I bought the bike it also had migrated magnets. So +1 for above.
Barbel Mick
Bike: 800RE
Reply #9 on:
June 15, 2022, 20:56:11 »
I wonder if the OP managed to get out of Bratislava?
Broker down DL1000
