Author Topic: Several warning lights  (Read 673 times)
Offline cargolion
  • Bike: F650GS, ANF125
« on: April 29, 2022, 21:33:10 »
First ride after fitting new front tyre; after a few miles ABS light on.  Soon after a misfire began, accompanied by flashing TCS light. Next came multifunction indicator light.  All three then on together, plus flashing F1. 2017 DL650 XA.
Any suggestions please?
Offline TLPower
Re: Several warning lights
« Reply #1 on: April 30, 2022, 06:56:04 »
Check the wheel is fitted the right way round with the ABS ring opposite the sensor, check the ABS sensor hasn't been damaged and check any wiring to the ABS sensor.
A roundabout way of saying it sounds like an ABS issue.
« Reply #2 on: April 30, 2022, 09:05:24 »
You also need to have a look at the fault code that is behind that FI.
 https://www.vstrom.info/Smf/index.php/topic,7061.0.html
« Reply #3 on: April 30, 2022, 11:15:38 »
Agreed .. what TL said ..
Seems a bit of a coincidence the problem has arisen after the back wheel was removed.
Offline cargolion
« Reply #4 on: April 30, 2022, 13:55:34 »
Thanks to all for your suggestions, right on the money!
Mea culpa - Roger, good bloke and proprietor of Fred’s Motorcycles in Blandford Forum, quickly spotted that I had nipped the ABS cable when tightening the brake callipers, causing a short.  Hence all the pretty lights.
With the cable repaired, all is well and I won’t miss my ferry to Cherbourg
« Reply #5 on: May 01, 2022, 07:19:56 »
Any before and after pix that you can share of the damaged section?
