Author Topic: How to get oil cap off without breaking it?  (Read 1697 times)
Offline bonne
  • Bike: DL1050 M0
« on: April 03, 2022, 14:03:31 »
The bloke chaging the oil last time has been tightening it way too tight.
How to get it off without breaking it?
Offline bonne
  • Bike: DL1050 M0
Re: How to get oil cap of without breaking it?
« Reply #1 on: April 03, 2022, 14:39:31 »
OK, I could use a large plier for it
Re: How to get oil cap off without breaking it?
« Reply #2 on: April 03, 2022, 17:01:13 »
An adjustable spanner will do the trick and not mark the filler cap.
Offline bonne
  • Bike: DL1050 M0
« Reply #3 on: April 03, 2022, 18:29:12 »
Yeah, OK... I used exactly this https://www.avxperten.dk/vandpumpetang/bahco-vandpumpetang-250mm-ergo.asp?gclid=CjwKCAjwi6WSBhA-EiwA6NiokxgemKjSsHCEIutxAn8K5f8NF4tkyBqWXyCLfqE8PPI9R8giZ9tspRoCHQEQAvD_BwE
Not sure about the English name... took some paper in between... and it didn't damage the cap.
Online Rusty Nuts
« Reply #4 on: April 03, 2022, 18:36:34 »
Gland pliers or water pump pliers are the two names that I know for that item.
Offline Tiggerbits
  • Bike: Suzuki GSF600 k2; Suzuki DL650 GTAL0
« Reply #5 on: April 03, 2022, 18:50:23 »
I have a knipex plier wrench which has been used to do this among alot of other jobs on the bike as it doesn't cause damage. Maybe a bit pricey for a single job.
Offline sillyboy
  • Bike: DL650 L7
« Reply #6 on: April 03, 2022, 20:35:53 »
as said, gland nut pliers or as we know them -- hens legs.
Offline Joe Rocket
« Reply #7 on: April 03, 2022, 20:38:21 »
Don't be fooled by tools for the job and go by your instincts bonne.
It's a solid plastic filler cap, nearly brand new, used less than a few times, not affected by sustained high engine temperatures (age), with oil below it's unlikely to seize (the casing it sits in is alloy).
Having said that I wouldn't use ordinary pliers from above just long nose pliers from the side for increased leverage. Put a wadding over the flange on the cap to avoid surface damage.
Finally clean and just tweak the cap a bit more than finger tight when replacing (like an oil filter).
Offline bonne
  • Bike: DL1050 M0
« Reply #8 on: April 09, 2022, 06:23:12 »
actually oil filter has to be tightened more than finger tight according to the service manual... but that is another story :)
« Reply #9 on: April 09, 2022, 07:27:44 »
Its almost starting to sound like the oil cap may have been cross threaded or abnormally tightened down.  Perhaps Bonnie can snap a pix or two of the oil cap, in relation to the engine casing.
A pix can be zoomed for a clearer view, to determine if any uneven gap, where the cap stops against the casing or foreign tool mark is present.
Offline bonne
  • Bike: DL1050 M0
« Reply #10 on: April 09, 2022, 10:05:11 »
I could take a pic, but I managed to get it both off and on again... it looks very normal and not ruined...
Offline The Doctor 46
  • The Doctor 46
  • Bike: DL1000A L4.
« Reply #11 on: April 09, 2022, 10:18:12 »
Dynamite! ............................... Oh sorry, I've just the original question again and noticed that you did mention, without damaging it.  :thumb:
Offline SteveDL1K
  • Bike: DL1000 K2, Honda CD200 (82) Kawasaki Z440 (82)
« Reply #12 on: April 09, 2022, 21:33:37 »
Ball peen hammer, Its easy smash all the casing in.
Get a pair of good knipex and nibble away at the edges and that should get your cap off with not a single scratch! :)
Glad you're sorted! :thumb:
Offline purplebikeunicorn
  • Bike: DL650A L7
« Reply #13 on: April 10, 2022, 05:23:24 »
Can confirm from my previous bike, that these plastic caps can be a right bugger to get off if tightened by a strongman. I did the same (molegrips, with some rubber in the jaws).
  • The Doctor 46
  • Bike: DL1000A L4.
« Reply #14 on: April 10, 2022, 12:50:51 »
I had a Honda XR250, I've had six XR's of different sizes, anyway. The oil is in the frame and the dip stick in the middle of the upper frame in front of the tank. It's awkward to get out but a nightmare to put back in, hence, the oil only got checked once a month. Nothing to do with your problem, just saying.  :icon_wink:
