Author Topic: Stock iridium plugs?  (Read 1299 times)
Offline bonne
  • Bike: DL1050 M0
« on: July 06, 2021, 22:34:24 »
Does the 1050 come with iridium plugs from factory?
Should the next plugs I buy for it be iridium, it it doesn't matter?
Re: Stock iridium plugs?
« Reply #1 on: July 07, 2021, 08:28:40 »
Yes they are iridium plugs from the factory. The 2014 on vstrom's use a different plug than the older stroms or the 650 and as far as I know are iridium only.  They are expensive plugs, over £20 each from a dealer but you can half that if you shop around. I change mine every 15k miles as manual says to but they looked fine, current set will stay in for 20k.
Offline hill100
  • Bike: DL1050XT M0
« Reply #2 on: July 07, 2021, 15:53:20 »
They only need replacing after 15000 miles while the previous model up to 2019 were replaced at 7500 miles
« Reply #3 on: July 07, 2021, 18:19:14 »
Iridium plugs can manage over 50k miles
« Reply #4 on: July 07, 2021, 22:19:33 »
£20 per plug for genuine...
2 years ago I paid £28 per plug after doing a load of cross reference and searching.
The Varadero (2003>) only had 2 options. NGK or NGK in a red Honda box. Both expensive!
Offline crofty
  • Bike: DL650, DL250
« Reply #5 on: July 07, 2021, 22:39:55 »
Quote removed
So are you saying that after 2019, Suzuki changed the official plug change interval to the 15,000 mile  service ?
Offline bonne
  • Bike: DL1050 M0
« Reply #6 on: July 07, 2021, 23:14:35 »
So if iridium can hold 50.000 miles, then why will Suzuki change them after 15.000?
« Reply #7 on: July 08, 2021, 07:52:38 »
Money.
Simply money.
« Reply #8 on: July 08, 2021, 08:41:29 »
If I remember genuine ones where £23 each from my dealer but that was in 2017 and remender you need 4. Got the next set from M&P for a tenner each.
My manual says 2 years or 15000 miles for the plug change on my 2014 model. I left them to 15k and they looked fine but as you need to remove the radiator to change the front plug and the tank for the rear I change everything while I'm in there. At 30k miles I set all the valves to mid settings plus new plugs so I'm not looking again till the 50k mark.
Offline Mr Nick
« Reply #9 on: July 08, 2021, 09:42:10 »
The iridium plugs in one of my old twin spark Alfas weren't due a change until 100k: it's purely cash grabbing to say they need done at 15k.
Orange Bikes Matter!
Offline Youngman
  • Bike: DL650 AL21, CBR954 '03
« Reply #10 on: July 08, 2021, 23:02:21 »
Like most things, 15k-50k-100k plug life is probably a bit of all the things mentioned.
The most common symptom of worn plugs is a hesitancy when you open the throttle. Not too much of an issue with the Wee, but new plugs in my 954 Fireblade with 30k on the clock has made a big difference to starting and eliminating the hesitancy. It still tosses its head when the beans are applied but its instant. I found my Wee's starting issues were all down to the light/starter cut out contacts BTW.
It's difficult to soar with the Eagles when you're really a Turkey
Offline STORMY
  • Bike: Triumph 1200 GT Pro
« Reply #11 on: July 12, 2021, 21:15:39 »
I changed my plugs at 7300 miles on my 1000 [AL8], I’ve kept them because they were in excellent shape. At the time I was changing the coolant / rad off etc and trying to pin point another issue so thought I might as well.
Found a good deal at this U.K. supplier
https://www.sparkplugs.co.uk/ngk-spark-plug-cr8eix-4218
« Reply #12 on: July 12, 2021, 21:47:57 »
Sorry but that isn't the correct plug for a 2014 on vstrom 1000, older model yes.
Offline STORMY
« Reply #13 on: July 13, 2021, 11:17:22 »
Thanks Porter - my saved link has been changed by the site….
This is the correct plug for an AL8 1000 (it’s actually cheaper)
https://www.sparkplugs.co.uk/ngk-spark-plug-lmar8bi-9-91909
« Reply #14 on: July 13, 2021, 17:43:48 »
Cheers Stormy for that link, I don't need any plugs for the vstrom but I did get a cheap set for my wee Suzuki not so swift. Cheers
