Tank removal DL1000 A8
Topic: Tank removal DL1000 A8 (Read 681 times)
STORMY
Bike: Triumph 1200 GT Pro
April 05, 2021, 23:01:44 »
Out foxed by a couple of cable ties
Do they simply unclip like a reusable cable tie?
Or
Do they detach completely from the plastic fairing without the need to open them up and remove the cables?
If they do detach from the inner fairing which way do I pull?
TIA
clutchspring
Bike: DL1000XT M0
Re: Tank removal DL1000 A8
April 06, 2021, 07:22:48 »
Hi stormy , it just pulls out , it takes quite a bit or force I sprayed some WD-40 behind it which helped, mine went back in OK .
Ian.
STORMY
April 06, 2021, 10:57:24 »
@ Clutchspring (Ian)
Thank you, I usually apply too much force and end up breaking plastics etc., this time I thought I’d ask
RoadWarrior1978
6000th Member
Bike: DL1000 L9
April 06, 2021, 11:48:13 »
I use one of these.
https://www.eurocarparts.com/p/am-tech-door-upholstery-remover-553777400?gclid=CjwKCAjwjbCDBhAwEiwAiudBy0kOnvQGEj8I6uElnQjvEShKh5lH9N6p8OcKsH7YiCaPnHCjKeq82RoC7oQQAvD_BwE
STORMY
April 06, 2021, 12:34:24 »
@RoadWarrior and so will I for £2.29 that’s definitely worth a punt - good suggestion thank you
