Author Topic: 1050 XT spokes pitting  (Read 2741 times)
Offline hill100
  • Bike: DL1050XT M0
« on: April 03, 2021, 15:09:04 »
The spokes on the rear wheel of my 1050 XT are starting to pit. No rust showing yet. Bike has not been ridden in the winter, and gets cleaned after a day out riding. The front wheel is perfect (so far).
Offline paulja
  • Bike: DL1000XT L8
Re: 1050 XT spokes pitting
« Reply #1 on: April 03, 2021, 16:54:25 »
They won't rust as they are galvanised. Might just be dirty, give one a clean and see. And yes, the front spokes seem to stay spotless (mine is still good at 30K) :shrug: Rear wheel gets dirty on a dry day- you will give up trying to clean it  :smirk:
« Reply #2 on: April 03, 2021, 18:31:29 »
Are these new spokes very different from the rusty spokes all over this very forum?
Offline clutchspring
  • Bike: DL1000XT M0
« Reply #3 on: April 03, 2021, 21:09:39 »
I thought the spokes were stainless steel !
Ian. :icon_exclaim:
« Reply #4 on: April 03, 2021, 21:13:55 »
Er, no. Sadly they are just some form of regular steel with zinc particles flicked at them with a paint brush. From a distance.
  • Bike: DL1000XT M0
« Reply #5 on: April 03, 2021, 21:31:54 »
 I would have thought the wheels on the 1050 xt would be the same as the 1000xt which are fitted with stainless spokes !
Offline Mr Nick
« Reply #6 on: April 04, 2021, 14:59:00 »
Ask Paulja as his were replaced under warranty: odd if they were already stainless don't you think. Maybe it's a fancy form of stainless that acts like mild steel?
Orange Bikes Matter!
Offline oslin
  • Bike: DL650A L5
« Reply #7 on: April 04, 2021, 16:38:17 »
There are several types of stainless steel some very good and some not so good, aircraft stainless is the best,
« Reply #8 on: April 04, 2021, 17:06:53 »
Years ago my mate complained to his mechanic about rusting stainless fasteners. Straight faced answer was "it's brown stainless."
Offline Mr Nick
« Reply #9 on: April 04, 2021, 17:37:06 »
There are many grades of stainless used in aircraft, commonly the 304 & 316 grades better known as A2 & A4, but also other specialist ones used like 631 for greater hardness, or temperature resistance like 321.
What you're likely to find on bikes & cars is 400 series as they're cheaper, but not as corrosion resistant, like 409 and 430.
Offline hill100
  • Bike: DL1050XT M0
« Reply #10 on: April 04, 2021, 19:33:52 »
Having read a few threads on StormTroupers, I tried cleaning the spokes with wd40 and gt85 with no improvement. But then tried T-Cut which removed what I thought was pitting and was in fact a stubborn film, which is only on the rear wheel. I use gear oil to lube the chain, and can't figure out what this film that looks like pitting and was near imposable to remove. This was a back breaking and time consuming job, so I have ordered XCP rust blocker in the hope that I don't have to do this to often.
« Reply #11 on: April 04, 2021, 20:39:47 »
If the spokes are galvanized as suggested above, then possibly a coat or two of cold galvanize should be sufficient. I would suggest that you try using cold galvanize in a rattle-can spray. A little prep work may be required prior to treatment. Also remember to first test for a colour match, before starting any touch up repairs.
Online UK_Vstrom650
« Reply #12 on: April 04, 2021, 20:59:05 »
The last bike I had with spokes, my old XVS125, I found lots and lots of Muc-off Miracle Shine and super-fine wire wool used to bring up them up a treat
« Reply #13 on: April 04, 2021, 22:44:58 »
I suggest a scotchbright not wire wool which can shed micro particles and cause rust.
Offline hill100
  • Bike: DL1050XT M0
« Reply #14 on: April 05, 2021, 11:39:05 »
This film which was a bugger to remove was predominately on the chain side if the spokes. I think that it may be a reaction between the lube oil (gear oil) and AC50. I gave the bike a coat of AC50 before I put it away for winter. As the front wheel is not affected, it looks like small black spec (oil) which looked like pitting.
  • Bike: DL1000XT M0
« Reply #15 on: April 05, 2021, 12:34:12 »
I know Honda have had problems with their spokes , quite a few owners have had them replaced under warranty on the Africa twin , there probably all the same poor quality fitted to most bikes.
Ian.
Offline vstroman
« Reply #16 on: April 05, 2021, 14:09:56 »
I wish Suzuki would offer the top spec Vstrom 1050 with cast wheels, I would not have a bike with spoked wheels, apart from my bicycle :dance:
