Author Topic: Battery specs ?  (Read 1978 times)
Offline Ijh
  • Bike: Currently riding a Vfr 800 but hoping to get a vstrom 1000 very soon
Battery specs ?
« on: February 28, 2021, 22:48:23 »
Hi all , can anyone tell me what the standard battery specs are for a 2017 DL1000 , e.g cca’s and ah’s , not had the bike long and don’t think the battery is standard .
Thanks
Re: Battery specs ?
« Reply #1 on: March 01, 2021, 06:29:30 »
What is the battery model on your L7?  If it is the same as the L6, then the battery will be a Yuasa YTX14H-BS with a capacity pf 20hr 12.6 Ah and a CCA (EN) of 200 Amps. https://www.yuasa.co.uk/ytx14-bs.html
Re: Battery specs ?
« Reply #2 on: March 01, 2021, 07:57:08 »
Fowlers don't list the most recent models but I'd be very surprised if it wasn't a YTX14-BS as all the DL1000's models and most of Suzuki's larger capacity bikes use that fitment.
Suzuki as standard supply either Yuasa meaning a YTX or a GS battery that will be a GTX14-BS.
Other battery models will fit the bike, some won't have the ccA.
But the YTX14-BS will be supplied by Suzuki 'dry' with an acid pack that the dealer will prepare when the bike is sold or becomes shop demo.
Check the date on the battery, sometimes on the bottom, if you really want to know it's age.
That however doesn't mean it was prepared at that date or that the dealer hasn't mixed up the batteries from various bikes. As the batteries are usually store in the stock room away from the bikes (and the sales blokes who should never be allowed to touch batteries).
In the dealers I worked in we kept batteries that belonged to new bikes on a shelf labeled with the stock number of the bike and the VIN so the correct battery made it's way to the bike.
Also, the bike is around 4 years old now and new batteries, even Yuasa ones only carry a years guarantee and 2 years warranty for manufacturing faults. So it's entirely plausible the original battery gave up the ghost.
Re: Battery specs ?
« Reply #3 on: March 01, 2021, 08:11:34 »
I'm my listings a 2017 model is YTZ14S .. 11.8ah , 230cca
A 2016 model is a YTX14BS, 12.6ah , 240cca .
Both batteries would work in either model ..
Re: Battery specs ?
« Reply #4 on: March 01, 2021, 09:56:10 »
Where did you find that reference?
I could only find up to 2016.
The YTZ is the higher cca but is also not as tall. There may not be the hight for the YTX on 17> models. Unless someone can confirm one is in their 17> bike???
Offline Bigcats30
  • Bike: DL1000 L8
Re: Battery specs ?
« Reply #5 on: March 01, 2021, 15:26:02 »
According to the manual
L4-L6 it requires a 12v 43.2kC (12Ah)/10HR battery
L7-L8 changed to 12v 40.3kC (11.2Ah)/10HR Battery
Ours is not to reason why, ours is but to do or die.
Offline user650
Re: Battery specs ?
« Reply #6 on: March 01, 2021, 20:33:11 »
From parts list on upload.
33630-48E00
If It Starts Ride It
Posh Paul
IBA Member
RBLR 1000 '18
Armistice 1000 '18
RBLR 1000 '19
RBLR 1000 '22
RBLR 1000 '23
RBLR 1000 '24
