Author Topic: Secondary removal - tps  (Read 821 times)
Offline bravis85
  • Bike: SV650
« on: February 18, 2021, 19:30:49 »
With the secondary throttle plates removal MOD, would it make sense to short out the secondary TPS so that the ECU sees the secondary throttle plates as always wide open(which they are). See what I mean?
Bonus question - if I've just put the primary and secondary TPS back on the bike, how do you calibrate the secondary?
Re: Secondary removal - tps
« Reply #1 on: February 18, 2021, 19:52:23 »
No.
With the secondary butterflies removes the position sensor should be left alone.
The secondary TPS gets self calibrated as the STVA cycles through it's range of motion.
Ps, unless you have and issue, put the plates back in.
It makes throttle response too snappy, prone to stepping out the back when you don't want it to, but it does smooth out the roll on roll off the throttle snatchyness.
I removed the plates on my K6 as I had an issue with a sticky STVA. I eventually cleaned it all out and put the plate back in.
Fuel consumption increased with the plates removed.
« Reply #2 on: February 18, 2021, 21:45:45 »
You'd think that with all the benefits you get from doing this mod Suzuki would not have fitted them in the first place.  Oh! hang on a minute........
« Reply #3 on: February 18, 2021, 21:53:46 »
 Brockett ...  :thumb:
Leave well alone unless you're adding a power commander ..
« Reply #4 on: February 19, 2021, 14:58:01 »
My tongue was in my cheek. Anyhow what would I do with extra power when there's nowhere to use what I have now?
Offline bravis85
  • Bike: SV650
« Reply #5 on: February 19, 2021, 17:26:24 »
Great, thanks for the info/reply.
Yes fuel consumption definitely seems on the high side.
They're under the seat so maybe I'll pop them back in.
No.
