www.v-strom.co.uk/shop
Barend remount on Vstrom 1050
Topic: Barend remount on Vstrom 1050 (Read 871 times)
bonne
Bike: DL1050 M0
December 13, 2020, 10:44:44 »
In the middle of installing Givi Handguards, and right barend is now removed (see attachment) - But I actually can't figure out how to reinstall it - it is like it doesn't really catch any grip. Can anyone in here give a hint, please?
kwackboy
Re: Barend remount on Vstrom 1050
December 13, 2020, 11:26:24 »
The nut at the end is spinning when you attempt to tighten the bolt at the other end.
Tighten the nut a little more to expand the rubber while it's out so when you insert it into the bar it grips the inside then, once the rubber grips it'll tighten easy.
Rixington43
Bike: DL1000GT K7
December 13, 2020, 11:28:16 »
Is that exactly as it came out or have you modified it at all to fit the hand guards?
On mine I had to slightly compress the rubber by tightening the bolt before I installed them. Get it to a point it takes a bit of a wiggle to force the bung up inside the bars and it should then grip enough to stop the end bolt spinning.
Rixington43
Bike: DL1000GT K7
December 13, 2020, 11:28:37 »
Snap 🤣
SimonW
Bike: DL1050XT
December 13, 2020, 11:43:27 »
Ironically I noticed mine was loose on the throttle side yesterday. I tightened it up really tight, but then the throttle wouldn't move. Slackening it off a little then pulling it out a couple of mm before tightening it up solved the problem.
bonne
Bike: DL1050 M0
Reply #5 on:
December 13, 2020, 12:31:10 »
It was like that when it came out, yes. And tightening it a little so that the rubber expands will make it tight so that it gets a grip. Thanks.
SimonW
Bike: DL1050XT
Reply #6 on:
December 19, 2020, 11:08:06 »
And then...it went stiff again the other evening (fnar). WTF? Ah, the heated grips were on, and the throttle rubber expanded just enough to bridge the gap to the bar end washer. One to watch out for if you have heated grips.
