Hi
I’m trying to fix this issue with a 2007 DL650.
The engine won't start...
Display mentions CHEC when powering up.
The previous owner sold it for following reason :
He forgot his keys (including alarm remote control) in his pants when washing ( this what he told to the dealer...)
Dealer removed the OEM alarm and wire loom, but since then it does not start. That is when I bought it...
I have the impression that the engine is OK, but that a wiring issue prevents the communication with the ECU or so?
The fuel pump does nothing when I turn the key, although it’s not broken ( tested with 12 volt and it pumps!)
I installed a new battery but of course this does not solve anything.
The OEM alarm was plugged in under the passenger saddle, with 3 plugs and without modification of the wires...
Tried to reinstall the wire loom and Oem alarm: no change.
Question: could it be that the alarm wasn’t correctly removed?
Did not find any mention of the OEM alarm in the wiring diagram.
Any help is welcome!
