If you didn't tap into any wiring recently, then perhaps you can try wiring a headlight bulb across the fuse terminals, to simulate a fuse. When a short occurs, the bulb will light as soon as there is a short to earth. This should save you on fuses while trying to trace the fault. You can push the harness around, to see what area might be causing the problem or shorting out.
