December 23, 2024, 09:27:45
Author Topic: DL1000 ECU Flash  (Read 2774 times)
Offline Himself
  • Adventure before ... errr...
  • Bike: DL1000A L6
DL1000 ECU Flash
« on: July 22, 2020, 16:22:42 »
Here is the edited highlight of what will be a longer article ...
2016 DL1000
Replaced the air filter with K&N
Replaced the end can with Delkevic
The bike is way smoother to ride. Roll on and off the throttle without any lumps, bumps or pauses while the exhaust clears itself
Tour of Scotland (just got back) and the end can joint with the link pipe was blowing slightly - black soot looks rich
Every fuel stop I was 3-4 litres more than the Africa Twins
Power Commander map or Fuel Controller - Parkit Engineering says neither - not required.
ECU can be flashed - bring it in and we'll run it on the dyno and map it out for mid-range torque and fuel economy while leaving it a little rich when you give it the herbs
Bike goes in on the 30th ... I'll let you know.
Interested in anyone comments though. I've seen posts about send away exchange ECUs but always thought generic maps would never be as good as a few hours on a dyno.
Cheers Himself
Offline sjrainsford
Re: DL1000 ECU Flash
« Reply #1 on: July 24, 2020, 12:35:12 »
Recently had my 650 done and it's made a bigger difference than I expected.  Definitely worth having a bespoke map done.
Offline kissofdeath
  • Bike: Veek
« Reply #2 on: July 24, 2020, 20:21:17 »
interested to know how you get on with this, and how much
Offline sjrainsford
« Reply #3 on: July 26, 2020, 19:28:59 »
Mine was £350 and would have been the same if it were a 1000 too.
Offline Himself
  • Bike: DL1000A L6
« Reply #4 on: July 30, 2020, 14:28:47 »
Longer answer is coming, I need to write the article ...
Short version
£385 inc VAT
  • V-Strom was very rich 11AFR overall (Lower the number the more fuel is present)
    Fueling cleaned up and mixture corrected - Target value for a V-Twin would be 13 AFR, mine is now 13.4AFR overall and 14 at cruising speeds
    Emission Step in the throttle bodies removed
    Tried removing the Deceleration Fuel Cut for added smoothness, but this caused blue flames out the exhaust. Not recommended useless you have sausages
    Mapped the exhaust servo value to open earlier in 4th 5th & 6th
Result - Better fuel economy (long run required) 2 more BHP and 2 more foot LBS of torque -- not that I was looking for that
Measured on the dyno at  90.51 BHP and 64.9 foot lbs - can't find the factory figures in the handbook
Dyno chart https://fliesonthevisor.com/wp-content/uploads/2020/07/V-Strom-Map.jpg
Offline Himself
  • Bike: DL1000A L6
« Reply #5 on: July 30, 2020, 17:09:08 »
I found the official figures -- 98.5BHP and 76 ft.lbs - Factory figures at the gearbox sprocket
Assume 5%-10% loss to get to the rear wheel and I should be seeing circa 90 bhp & 70 ft.lbs whereas I'm getting 90.51 bhp and 64.9 ft.lbs. Power is about right but torque is down further.
The bike is still epic and now slightly more epic than it was this morning :)
Offline Himself
  • Bike: DL1000A L6
« Reply #6 on: August 03, 2020, 18:20:09 »
150 miles later and I'm happy.
The whole story - soup to nuts - can be found here https://fliesonthevisor.com/ecu-flash-road-test-results
The V-Strom is great fun as standard, but if you tweak it to make it your own, an ECU map is that perfect finishing touch.
Offline TLPower
« Reply #7 on: August 03, 2020, 20:39:44 »
I thoroughly enjoyed reading your thoughts and experience of ECU flash. Your riding impressions and results mirror my feelings after having my KTM "flashed". Flexibility and refinement were the biggest improvements I felt, though the the extra mid range  push at 6000 to 9000 rpm is very exhilarating and intoxicating.
MPG is very acceptable still for a 1200cc V twin, motorway slogs see 60 mpg, progress on A and B roads sees mid 40's to low 50's.
Offline Himself
  • Bike: DL1000A L6
« Reply #8 on: August 04, 2020, 13:59:50 »
Thank you TLP ... I do enjoy "scribbling"
Now if only I could get the V-Strom to 60mph on a motorway ... perhaps if I slowed down a bit  :angry-banghead:
