Away in Germany. I noticed that the rack for the top box was not sitting tight enough. Maybe it had become loose on the Autobahn. The top box is mounted on a top box adapter which again is mounted on a rack adapter that then sits on the Suzuki rack. In order to mount the rack adapter on the Suzuki rack, the two existing bolts needs to be replaced with two different bolts (as well as two additional new bolts) that comes with the rack adapter. These two bolt became loose.
Do you follow this far? (:
The problem now is that I can only tighten one of these the other one does not get a grip as if there is nothing to get on to.
I was thinking that the thread (is this the correct English word?) was firmly attached to the Suzuki rack, but I guess not.
It was too dark for me to see clearly enough, but two questions:
How do I manage to get the last bolt to grip decently, and will three bolts be enough to hold the top box until I get it fixed? At least when I am aware of it now
