It’s time to change the brake / clutch fluids on my Strom, I need some plastic pipe to complete the task - does anybody know the correct size pipe I need (looking on eBay they seem to range from 4mm to 7mm internal diameter.
Also looking at lowering the pegs maybe with some SW Motech products that’ll take it down 15mm, or I may try another route with another supplier like Kosmo or Cymarc they lower the pegs by 25mm.
Question: The Kosmo kit uses a plate to drop down the brake pedal, you get an extension for the brake rode but I see no extended spring for the brake light switch.
The SW Motech pegs simply attach to the existing fitting, and using a clever connecting bracket allows the pegs to move from stock height to 15 mm below etc. Would the existing brake light spring and brake rod handle a 15mm drop on the pegs?
Failing that is there somewhere I can source a longer spring should it be required?
Thanks
