Author Topic: Do Glees rattle in neutral?  (Read 982 times)
Offline Sea-Strom
  • Bike: DL1050A (2022), Fat Bob (2023), Softail Standard (2023)
« on: June 26, 2020, 23:24:06 »
Having tried a 2015 and 2020  650 back to back recently, I noticed the Glee rattled a bit in neutral and went quieter when depressing the clutch. The new model was much quieter ticking over with the clutch in much the same. So is this a noisy engine example or are the latest beaky versions all quieter?  :shrug: Thoughts on this welcome please.
Offline graingerblaze
  • Bike: DL1050
Re: Do Glee's rattle in neutral?
« Reply #1 on: June 27, 2020, 00:38:10 »
I can't comment on newer bikes but my K5 (2005) doesn't change sound when the clutch is pulled in.
If you have a centre or paddock stand, does the rear wheel rotate slightly when in gear but the clutch pulled in? If you have any clutch slip I guess that could cause some noise variation.
I doubt you have any clutch basket issues, that tends to be the 1000... Although the springs can seize up if the bike is left standing for long periods of time. Again unlikely but trying to think of possible issues...
 :shrug:
DL1050 Grey (2020) V-Strom
« Reply #2 on: June 27, 2020, 05:24:39 »
Perfectly normal, I'd say. My glee always sounded a bit quieter with the clutch lever pulled to the bar. Not really a rattle as such with the lever out, just a louder drumming. Just the unloaded parts of the gear train spinning, as with many bikes, I imagine.
Re: Do Glees rattle in neutral?
« Reply #3 on: June 27, 2020, 09:55:27 »
Having had two Wees and one Glee I'd say there is a mechanical noise that is deadened when the clutch lever is pulled back. I suspect the clutch basket has some play in it which gives it a light knocking sound. This can be much amplified by a sump guard which throws the sound upwards. My Vee had the beginings of the usual clutch knock that can be cured by the "Sharealike|" modification.  On the 650, think of this as a "feature" rather than a "fault". Stay in gear, keep the throttle open and don't give it another thought.
« Reply #4 on: June 27, 2020, 10:02:47 »
My Glee does it.  :thumb:
« Reply #5 on: June 27, 2020, 10:45:59 »
My wee did it.
My Varadero does it.
SWMBO's GSX14 does it
Most Yamaha engines can be heard at 100yrds.
« Reply #6 on: June 27, 2020, 11:10:21 »
This is a rattling clutch
Offline hotbulb
  • Bike: DL650 L4
« Reply #7 on: June 27, 2020, 11:20:29 »
What size nails are in the bag to make that noise?
Offline Sea-Strom
« Reply #8 on: June 27, 2020, 16:03:06 »
Thanks for replies - as always, spot on. :thumb:
Offline doboy
  • Bike: 1050 v strom
« Reply #9 on: June 30, 2020, 19:27:06 »
I've had three 650 v strom,s all three had clutch rattle in neutral , never had a problem with any of them , its normal ..just ignore it .
