I too seem to blind every cage dweller who happens to be coming towards me when two up. When you say "crank up" do you mean wind it up to five ? mine is set at 3. The other half wheighs in at 10 stone but I am a bit of a fat knacker at 15 1/2 stone
crank it up to full all the time the rear unit is woefully undersprung ... if it feels harsh ..back off the rebound ...if it feels bouncy crank up the rebound ...the only cure especially two up is a new spring or rear shock om afraid
hagon do a good basic unit for around 260 quid [no remote preload ] ... spring sets front and rear aroun90 quid ..the difference is emmense if you do the spring avoid progressive they make more sense on hard ridden bikes ..
I fitted ohlins to the rear 650..but used hagon on the 1000
its a very very good unit I rate it as effective and easier to use than the ohlins ...
if u intend to run your bike long term its a no brainer ...still get half the money back if u e bay them when you sell
By
minkyhead at 2008-11-10
By
minkyhead at 2008-08-27
By
minkyhead, shot with
u30D,S410D,u410D at 2008-11-10
