Alreet Lads. Could do with any input about an engine oil leak on a DL650 2013.
The engine is mainly moist on the right hand side. The wettest component is the nut that is on the end of the main mounting shaft/bolt at the front of the engine. The one that hangs from the V part of the frame. The V part of the frame above this is dry. Can't see or feel oil above the engine mounting bolt.
Thanks
