Author Topic: 1st Time & No Power to Ignition  (Read 793 times)
Offline livebytheleaf
  • Bike: DL650 L1
« on: May 09, 2020, 18:59:48 »
Hello my UK riders - Your Canadian rider needing some help.  I just charged my battery and ready to ride - turned on the ignition - power on for a few seconds, then nothing.  Re charged battery - no power to ignition.  Check the ignition fuse and replaced with spare - no power.  Do you think I need a new battery??  2011 650 DL - not much of a mechanic, so any help would be great - thank you !!
Re: 1st Time & No Power to Ignition
« Reply #1 on: May 09, 2020, 19:03:46 »
Just double check the battery cables are tight. If they are, if it is an original battery then I would be tempted to suggest it is dead.
« Reply #2 on: May 09, 2020, 19:11:48 »
Do the lights come on?
  • Bike: DL650 L1
« Reply #3 on: May 09, 2020, 19:15:43 »
Thanks - it is the original battery and lights do NOT come on
Online MartinW
« Reply #4 on: May 09, 2020, 19:15:52 »
That's not an intro so I am moving it to the general section as more members will see it here.
I suspect Tallpaul has given you the right answer.
« Reply #5 on: May 09, 2020, 19:18:01 »
 :welcome2: I agree with TP , probably the battery if it's original.
  • Bike: DL650 L1
« Reply #6 on: May 09, 2020, 19:21:14 »
Sorry, I will review the site and post properly next time - appreciate the direction and advice Tall Paul
« Reply #7 on: May 09, 2020, 19:33:16 »
You're welcome! Hope it helps you sort your bike out.  :thumb:
Offline bosnjo
  • Bike: DL1000 L7
« Reply #8 on: May 09, 2020, 22:02:55 »
You can always use jump cables to connect it to your car or other motorcycle (I've tested that way my battery on '12 650). If you get the power that way then your baterry is gone for good.
DL1000 2017 white
DL1000 2014 red (sold)
DL650 2012 white (sold)
