Bullets are inferior and would end up being massively bulky. Is the lug broken? If not, I'd photo the blocks, write the colour sequence out, remove, clean, replace all wires in both halves. Then cable tie a bit of inner tube round the connector - even use corrosion block grease first if you've got some.
