Thanks Paul,
Really appreciate your help. They were a sod to get out but I managed it. Just tried it all out and Hello presto
brake lights and aux light working as they should.........
Then I tried to start my bike up, and no go - just a clicking from the rear of the bike, which I assume is the sound of relay to the starter motor. The ignition sequence, lights, fuel pump all working as it should when the ignition switch is switched on??
I’ve had the bike on trickle charge all winter, so shouldn’t be the battery - but just plugged it in again overnight to rule this out.
I’ll check the fuses tomorrow as well...any thoughts?
