Author Topic: Leaking oil sight glasss  (Read 1258 times)
Offline Paulnorth
  • Bike: 2002 vstrom DL 1000
« on: March 17, 2020, 23:04:02 »
Hello everyone. I've just recently joined your forum.
Hoping to get some advice.
My 2002, DL1000 oil sight glass seems to be leaking oil.
Best action....is it an engine casing off and try to remove and reseal. 3 day delivery wait for a new glass. Are they difficult to reseal. Type of gasket on casing to?
If anyone has had similar problem and solution?
Regards Paulnorth
Re: Leaking oil sight glasss
« Reply #1 on: March 18, 2020, 06:25:13 »
Not sure whether it is a seal or a pressed fit. Closest example that I can find is item #2 in https://www.partzilla.com/catalog/Suzuki/motorcycle/2002/v-strom-DL1000/crankcase-cover, then selecting the item in the part numbers https://www.partzilla.com/product/Suzuki/11971-33210?ref=04263b0a684af9b945b43b50c34ca1656150bec1 which it appears to have it's own seal. I could be wrong in this assumption.
Have you approached any Suzuki workshop for some advice?
Offline sjrainsford
« Reply #2 on: March 18, 2020, 13:35:27 »
Have you tried using a socket of the right size to give it a gentle tap into the casing?  It may help.
Offline Paulnorth
« Reply #3 on: March 19, 2020, 15:55:15 »
Thanks for the replies. Good news I found out not the oil sight glass. Changed oil and filter.
Leaking from a threaded hole, below the coolant bleed bolt. 90 degrees to the casing machine screws? I will try and load pic.
Offline Paulnorth
« Reply #4 on: March 19, 2020, 15:58:50 »
The oil is leaking from hole that blue wire is placed. It's not a blind threaded hole. Not sure if blot or grub screw has vibrates loose. Any ideas?
Thanks in advance.
« Reply #5 on: March 19, 2020, 16:07:20 »
https://www.v-strom.co.uk/downloads.htm
Have you seen the Downloads section for a manual.
Offline Paulnorth
« Reply #6 on: March 19, 2020, 16:28:39 »
I've looked on parts list. I think it's no.9 clutch water drain. Ty
Offline Paulnorth
« Reply #7 on: March 19, 2020, 16:32:32 »
No.9 bolt and washer. can't understand how it's worked loose and could be anywhere in Northumberland...
Offline Paulnorth
« Reply #8 on: March 19, 2020, 17:11:06 »
Just looked again....its a hole below the no.9 bolt. Doesn't seem to be threaded but oil dripping out when engine is running. Any ideas to why or what fits into hole. If any?
Offline Paulnorth
« Reply #9 on: March 19, 2020, 17:14:42 »
« Reply #10 on: March 19, 2020, 18:57:41 »
Looks as if it could be the water pump “tell-tale” hole.It weeps water or oil if either side is leaking.It stops the water contaminating the oil and Vice-versa.The 650 has a different arrangement doing the same thing.
« Reply #11 on: March 19, 2020, 19:02:41 »
Just spotted another post with the same pics.Has it been doubled up Paulnorth ?
Offline Paulnorth
« Reply #12 on: March 20, 2020, 00:24:55 »
Yes same problem. Cheers.
Finally got it to leaking from breather hole.
