DL1000 K7. Owned this for nearly 6 yrs and has taken me on several Scotland tours. Looking for something that the wife is more comfortable on the back off (probably a ST1300 or RT1200). Mileage is approx 45k. Home serviced by myself apart from first service after buying it. Recently had the clutch basket modified by sharelike (vibefree). Clutch and flywheel covers have been painted black due to the usual corrosion issues with the water pump. Forks, swing arm and sub frame re-sprayed to keep up with normal wear and tear issues. Full luggage set. Both keys with the bike. If you need any more info then please message me. Will be sold with full MOT.
