Author Topic: Loss of power  (Read 2564 times)
Offline Gary lad
  • Bike: SUZUKI DL 650 AK7 GT
Re: Loss of power
« Reply #20 on: February 05, 2020, 17:52:57 »
Thanks Paul for your input I will have a look thought I would try and adjust first
Offline Gary lad
Re: Loss of power
« Reply #21 on: February 05, 2020, 17:56:59 »
I have done it when the engine is warm also now need a special torx to complete not got one in my kit
Offline Gary lad
Re: Loss of power
« Reply #22 on: February 06, 2020, 13:48:51 »
Would like to thank all on the group for your help re the TPS sensor and losing power situation altered the TPS this morning and just took it out for a test ride only 10 min but touch wood all is OK will be the test tomorrow as got a 50 mile ride and thanks too all
Cheers blokes
Re: Loss of power
« Reply #23 on: February 06, 2020, 14:06:12 »
Hope all is sorted, well done    :thumb:
Re: Loss of power
« Reply #24 on: February 06, 2020, 17:18:12 »
Downunder did you use a new o- ring on the tank to pump seal or was it OK to reuse. I've  the tank off mine at the minute so was thinking I'd to this while its all apart.
Offline Gary lad
Re: Loss of power
« Reply #25 on: February 06, 2020, 18:14:48 »
Porter used the original as it was OK
Offline Silverback
  • Bike: DL650 K7
Re: Loss of power
« Reply #26 on: February 06, 2020, 18:44:41 »
Had similar symptoms on my 650k7. Changed the TPS now runs great.
Rather than reading the voltage when turning the throttle I disconnected the plug and measured the resistance between 2 of the pins whilst gently turning the throttle looking for sudden spikes in the readings. Mine was giving different readings on closed throttle,especially when gently closing the throttle (the action you would use filtering and stopping in traffic) Symptoms was cutting out at idle and loss of power. It's a while ago now but if you're struggling I'll dig out the testing papers I used. A new one is around £90.
Re: Loss of power
« Reply #27 on: February 06, 2020, 18:58:52 »
Cheers Gary, I looked  online and its 35 quid for a new o ring! I know I'm a cheapskate!
Re: Loss of power
« Reply #28 on: February 06, 2020, 21:44:47 »
'OW MUCH!!!??? 35 fahurkin' quid for a hole with a neoprene collar!! Is it a unicorn size and profile?
Re: Loss of power
« Reply #29 on: February 06, 2020, 22:01:46 »
#yorkshirebattlecry
Those are BMW prices.  :crazy:
Re: Loss of power
« Reply #30 on: February 06, 2020, 23:11:55 »
The oe fuel strainer is 53 quid, luckily you can get a pattern of ebay for a tenner.
Offline Downunder
  • Bike: Vee2
Re: Loss of power
« Reply #31 on: February 07, 2020, 20:55:21 »
I used the original big o ring and all of the small ones too. Even thought the workshop manual says to replace them all. I saw the knock-off filters on Ebay but just went with OEM as it was quicker to obtain it and it was only 42 AUD or 21 GBP.
Richmond, NSW, Aus
DL1000 ABS 2014
Offline Gary lad
Re: Loss of power
« Reply #32 on: February 08, 2020, 12:05:26 »
Just a quick update RE TPS sensor nice smoother ride then on way home did it again blinking heck thought I had solved the issue of power loss obviously not now it seams to do it when the engine is hot only also my temperature gauge fluctuates all the time from four bars down to two is this normal blokes
Re: Loss of power
« Reply #33 on: February 08, 2020, 17:10:28 »
Suzuki uk ripping us of again! The fuel strainer is £53.00 here. Ebay one for me.
Re: Loss of power
« Reply #34 on: February 09, 2020, 06:01:47 »
It's starting to sound more like an electrical fault, since the comment in your previous post and I quote: "temperature gauge fluctuates all the time from four bars down to two is this normal".
I suggest that you inspect the connectors above the radiator for burnt / bad connection, as well as the power and earth connection points (battery terminals and earth strap).
How does the voltage look across the battery, with ignition on but not started? Then again the voltage reading, with the engine is running around 3,000 rpm? For a good charging system, you are looking for a reading in the region of 13 - 15 Volts at 2,500 - 5,000 rpm. Ensure that no accessories are drawing power when testing, as this could give a faulse reading.
Offline Gary lad
Re: Loss of power
« Reply #35 on: February 09, 2020, 09:44:03 »
Thanks for the reply I will check all the above
