Author Topic: Another computer query  (Read 1197 times)
« on: January 08, 2020, 18:08:33 »
The clock on my laptop is 6 minutes fast.
I've never seen it to be incorrect before.
Is it about to die?
What should I do about it?
Offline Ridaz
  • Site Donator
Re: Another computer query
« Reply #1 on: January 08, 2020, 18:12:51 »
Hi Dave
You can set it here or at the least, check what your laptop settings are following this process.
https://www.techjunkie.com/fix-incorrect-windows-clock/
Hope it helps
« Reply #2 on: January 08, 2020, 18:46:33 »
Thanks Ridaz. But.... I did the old switch off wait a few minutes and switch on again and it seems to have righted itself. Very curious.
« Reply #3 on: January 13, 2020, 10:27:42 »
Windows 10.   Over the last few days the PC has developed a stammer with everything taking forever.  Task Manager shows something called WMI Provider Host    is using between 17% and 28% of CPU alternating every  2 seconds. Power usage is shown as 'very high. I have Googled it and sort of know what it does and have found many many PC users complaining of the same fault without being able to find a ' safe cure'. So far the fixes offered date back to 2013 and are shown by "Malwarebytes" to be "trojans and are shut out. I suspect the fault is so widespread that naughty people are pretending to offer a fix while instead inserting a program that "pulls your pants down".
Has anyone else had this problem and how did you fix it?
« Reply #4 on: January 13, 2020, 12:36:25 »
The recommended fix for this is to restart Windows Management Instrumentation which located in the services section ( services.msc).
However when the restart option is selected there is a message that the action is not possible. Avira antivirus and Malwarebytes  are programs that I have installed and these are somehow locked into the WMI Host process alond with a system program ( IP Helper) .
I uninstalled Avira and Malwarebytes one at a time and tried for WMI reset. No change but it did allow me to restart  Windows Management Instrumentation and then restart the PC When I restarted the PC the problem was gone.
However I now have no Antivirus or Malware removal tool.
I am thinking that the WMI was acting up after a microsoft update and the other two programs were not the issue but were preventing  the recommended fix ie. restart of the WMI . I will try to reiinstall the Avira antivirus and see what happens.
Offline Mr Nick
« Reply #5 on: January 13, 2020, 17:22:42 »
I have 3 instances of WMI running: one of which is 32 bit. Only one shows using any CPU resources at about 0.1 - 0.2%, and there's 22MB RAM over all 3. I got rid of Malwarebytes a little while back as it conflicted with something else, probably my Kaspersky have.
Windows 10 Home 1809: up to date, but I haven't installed the 1909 'features update'.
Orange Bikes Matter!
