Author Topic: Power commander  (Read 1694 times)
Offline Jez6640
  • Bike: DL1000 K8, 1998 Fireblade, 2016 MT10
Power commander
« on: September 21, 2019, 20:53:07 »
Has anyone seen any videos on how to fit a power commander to a v strom, going to try and fit one myself but can't seem to find any youtube vids for a v strom
Offline pichulec
  • Bike: KTM 1290 SAS
Re: Power commander
« Reply #1 on: September 21, 2019, 21:01:51 »
Why don't you look at source?? Found it in 2 minutes....
http://www.powercommander.com/downloads/311/install/211/eng311-211.pdf
Offline Jez6640
Re: Power commander
« Reply #2 on: September 21, 2019, 21:15:33 »
Yep would do if I knew what source was??
Offline Jez6640
Re: Power commander
« Reply #3 on: September 21, 2019, 21:18:44 »
Also that doesn't help it's for the 111 that has been replaced by v which is a different fit.
Re: Power commander
« Reply #4 on: September 21, 2019, 21:24:49 »
Are you talking about the PCIII ..? if so they are not made anymore.
The PCIII is a piggy back ECU that just plugs into your existing loom and the black wire connects to the battery earth.
Best place to put it is in the tool tray under the seat and run the wires down the inner side of the frame , under the tank and eventually into the loom plugs . It's pretty straight forward.
Offline Jez6640
Re: Power commander
« Reply #5 on: September 21, 2019, 21:42:31 »
No the 5 can't get 3 anymore which is the link posted which nor a video of relevent
Offline D16PJM
  • Bike: BMW R1250GSA, David Jefferies R1, ZX9R, Suzuki T20
Re: Power commander
« Reply #6 on: September 21, 2019, 22:05:21 »
can you not buy any power commander 3 and then the associated kit for your bike or healtech for that matter, I've not looked into it so not 100% but worth a look
Pete
Offline pichulec
Re: Power commander
« Reply #7 on: September 21, 2019, 22:42:12 »
Power commander 5 for DL1000 - not an video but install is so simple that video is not needed.
https://dynojet.co.uk/media/attachment/file/2/0/20-017.pdf
Offline hookie
Re: Power commander
« Reply #8 on: September 22, 2019, 15:06:12 »
Being a tight arse I bought a used PC111 USB for K8 Vee. (Think I paid about £80 off Fleabay). Fitting was easy and straight forward until the issue of the Oxygen Sensor fitted to UK bikes cropped up. The downloadable maps on the PC site only has four for European spec. All European bikes have an O2 sensor fitted as standard. One map for a standard bike with it's O2 sensor connected and the rest with it disabled including two where things like the air filter and exhausts have been changed. I don't know what other maps are available for later PC versions. Disabling the O2 sensor was where the fun began. At that time I couldn't find anyone selling a simple disabling plug to fit into the O2 wires after I'd disconnected it, which meant I then had to disconnect a wire from the bike's ECU to stop an error message popping up on the dash. It turned out that there are at least two wiring systems used on my year bike and it took a lot of rummaging around to find the right wire to pull. PC in the States couldn't help and I could find any PC centre in the UK that could give a proper answer. Got there in the end and it's been fine ever since. On the PC111 you can adjust fuelling using the buttons on it but the best way if you can afford it is to have it done by a proper PC centre on a rolling road. I fitted it to try and improve the fuel consumption, which it has done by just a few m.p.g. as I've always felt it ran over rich at low to middle r.p.m., which is contrary to the accepted view. The map I use has leaner settings than the standard one for the bike. The bike has a TRE on it, a pair of carbon fibre cans (that make it sound like a proper bike), and a BMC air filter. It runs very nicely and has no issues with low speed, chugging through towns and will happily run at 2,000 r.p.m. in lower gears without any issues. So all in all it was well worth fitting.
