Author Topic: 2010 650 stalling  (Read 1144 times)
Offline roganjoshing
  • Loving my first Vee Twin
  • Bike: DL650 L0
2010 650 stalling
« on: August 30, 2019, 10:51:30 »
My 2010 (L0) 650 has begun stalling.  It starts and idles but once riding tends to idle too low and occasionally stall.  Cold and warm.  Typical time is when entering a roundabout or approaching traffic in second or third under engine braking, then pulling in the clutch to stop - it stalls.  Starts easily with one prod of the starter and then may idle OK.
Any ideas?  Is it an easy fix (bearing in mind I am far more familiar with carbs than injectors)
Re: 2010 650 stalling
« Reply #1 on: August 30, 2019, 11:32:39 »
Throttle Position Sensor would be my first guess.
« Reply #2 on: August 30, 2019, 11:43:53 »
I second the TPS.    :thumb:
  • Bike: DL650 L0
« Reply #3 on: August 30, 2019, 12:16:37 »
Cheers. Does that mean a new one?
« Reply #4 on: August 30, 2019, 12:20:39 »
If the issue is the TPS then yes .
Offline Silverback
  • Bike: DL650 K7
« Reply #5 on: August 31, 2019, 19:01:46 »
My 650k7 had exactly the same symptoms. New TPS cured it,around £85 for a new one.
You can check them with a meter but its not always easy to spot the spikes in the readings.
Good news is its easy to fit,you will need to put the bike into dealer mode to set it up.
It's a subject that's been covered several times before so a quick search should give you the info you need.
« Reply #6 on: September 01, 2019, 07:18:58 »
For some info on a TPS, https://www.sportbikes.net/forums/fz6-fz6r/7320-throttle-position-sensor-issues-you-experiencing-poor-idle-mileage-stalls-25.html#post2105110 post #366 - #368. The complete thread is interesting, if one has the time.
  • Bike: DL650 L0
« Reply #7 on: September 02, 2019, 17:12:15 »
Thanks everyone. I'm on it.
« Reply #8 on: September 03, 2019, 06:54:24 »
Let us know how it works out. Remember that the thread on security torx screws (used to hold the TPS in place) are very soft and damage easily, so don't over tighten.
