Author Topic: Centre stand DL1000 /XT1000 2018  (Read 816 times)
Offline Paulreade
  • Bike: DL1000XT
« on: August 05, 2019, 18:24:16 »
I have recently bought , fitted and just removed a constands centre stand. I was about to order one from sw- motech and their stand appears identical - thoughts are am I going to have a similar issue. Has anyone fitted a constands product and had issues with the bike not sitting properly. The issue mainly relates to the left bracket hitting the underside of the frame and wearing a groove or pocket and the right side of the stand not contacting fully when down.
Offline LusyLew
  • Bike: DL650 L6
Re: Centre stand DL1000 /XT1000 2018
« Reply #1 on: August 05, 2019, 20:59:37 »
I had a constands main stand on my TDM.
Whilst it looked sturdy enough, it didn't seem to  hold the bike completely level, so I never 100% trusted it...
Offline bako
  • Bike: DL1000A L6
« Reply #2 on: August 05, 2019, 23:36:06 »
Fitted an SW-Motech centre stand to my BMW 650 Dakar. The fit was OK but felt flimsey.
I have the OEM stand on my 2017 DL1000 and it's solid. Had it as part of the accessories package they were doing when I bought the bike.
Offline Paz324
  • Bike: CB1000RAJ
« Reply #3 on: August 06, 2019, 06:07:59 »
I had an SWMotech stand on my AL8 before I sold it, no issues what so ever..
« Reply #4 on: August 06, 2019, 07:33:10 »
Why not grind away the section that is binding? From your 2nd pix, it only needs about 2-5mm for enough clearance. I wouldn't go any more than that for fear of weakening the construction. Mark with a sharp object to ensure the correct area is being reduced. Since you already have the stand it won't cost you anything but time, labour and duco / spray paint to protect the metal. If you don't have a grinder, perhaps someone near you can help?
Offline Paulreade
  • Bike: DL1000XT
« Reply #5 on: August 06, 2019, 16:08:04 »
I have actually reached the conclusion that the stand is not actually for the bike and have therefore placed a complaint with the supplier. I have decided to go the oem route and have one from Suzuki. I think if I'd have started to make it fit!, I might never have been 100% happy with the fact that it did not fit the bike as promised and trusting the stand to keep the bike upright is paramount.
Offline RoadWarrior1978
  • 6000th Member
  • Bike: DL1000 L9
« Reply #6 on: August 07, 2019, 18:43:13 »
 I also bought a Constands centre stand and encountered the same issues,  however I went down the make it fit route.
The bike doesn't sit perfectly but it's okay,  if it wasn't for the fact it cost almost a third of the OEM one I'd have sent it back.
