Author Topic: Driving lights  (Read 1115 times)
Offline Maddog123
  • Bike: DL650 L0, Triumph Speed Twin
Driving lights
« on: July 29, 2019, 19:10:58 »
If I fit lights to my v strom can I just turn them off with key or do they have to be on switch ,I was thinking of just putting them in to new fuse box .
Re: Driving lights
« Reply #1 on: July 29, 2019, 19:33:03 »
That would depend on what type of power output the lamps have. If you use a relay switched fusebox then that would mitigate some of the initial load, using LEDs would be ideal.
Re: Driving lights
« Reply #2 on: July 29, 2019, 20:15:53 »
You could have them on a switch via the ignition so, when you turn off your ignition the lights turn off even if you have left the switch on.
As Fat Rat says , LED is a good way to go .
Offline Maddog123
Re: Driving lights
« Reply #3 on: July 29, 2019, 21:47:41 »
Thanks for input lads .
Re: Driving lights
« Reply #4 on: July 30, 2019, 07:53:20 »
I support the call for a relay plus a separate switch for the driving lights. Driving lights can thus be switched on / off on demand, without turning off the ignition. You never know when there maybe a need to switch off the extra lights, either for oncoming traffic or for animals, to conserve battery power, etc. Just remember to wire in a fuse for the driving lights power supply.
