strange noise
Topic: strange noise (Read 1367 times)
kissofdeath
Bike: Veek
strange noise
July 25, 2019, 19:58:28 »
please view the video on FB as it wouldn't load on here.
https://www.facebook.com/paul.roper.169/videos/o.2487630994/10158598461275130/?type=2&theater¬if_t=video_processed¬if_id=1564081007490754
kissofdeath
Bike: Veek
Re: strange noise
July 26, 2019, 13:19:14 »
Brockett
Bike: 2022 Moto Guzzi 850 V7 special in blue, 2022 850 V7 Stone in darkest black, 1998 XJ600n in red. 2021 Royal Enfield 500 Classic stealth.
Re: strange noise
July 26, 2019, 13:44:10 »
Hard to separate the noise of wind on the mic or your sleeve which can be seen flapping.
what can you hear?
Fingers crossed it's not wheel bearings eh?
kissofdeath
Bike: Veek
Re: strange noise
July 26, 2019, 13:54:09 »
Quote from: Brockett on July 26, 2019, 13:44:10
sounds very similar, just going to check the chain now
kwackboy
Re: strange noise
July 26, 2019, 14:21:59 »
Hard to tell as there is so much background noises but I shall have a dabble and say sprocket hub bearing ..
kissofdeath
Bike: Veek
Re: strange noise
Reply #5 on:
July 26, 2019, 14:30:45 »
well I've checked the chain and there does seem to be a tight spot on it so have cleaned and re-lubed, can't adjust at the moment as I gave all my loose sockets to my daughters BF
and can't undo the wheel
what size is the nut so the missus can search for one tomorrow while I'm at work?
kwackboy
Re: strange noise
Reply #6 on:
July 26, 2019, 15:12:46 »
24mm I think
Paz324
Bike: CB1000RAJ
Re: strange noise
Reply #7 on:
July 26, 2019, 15:30:48 »
Rear axle nut is 36mm on the 2014+ models.
kwackboy
Re: strange noise
Reply #8 on:
July 26, 2019, 16:32:11 »
, haven't seen a new Veek for ages .
bako
Bike: DL1000A L6
Re: strange noise
Reply #9 on:
July 28, 2019, 00:29:16 »
How slack is the chain? Sounds like it could be too loose and jumping the sprockets on accelaration. If not that there's and expensive bearing job on the horizon.
oslin
Bike: DL650A L5
Re: strange noise
Reply #10 on:
July 28, 2019, 13:14:07 »
if the bearing is gone you should be able to feel it when you spin the wheel on the stand it will feel slightly rough or knotty rather than very smooth also check the chain for seized links and the correct slack
kissofdeath
Bike: Veek
Re: strange noise
Reply #11 on:
July 28, 2019, 20:46:33 »
shhhhhh people, stop saying the f*****g B word
strange noise
