www.v-strom.co.uk/shop
Trim Clips (again)
Topic: Trim Clips (again) (Read 827 times)
Fritz
Bike: DL650 K9
Trim Clips (again)
June 06, 2019, 14:18:33 »
Wee Trim Clips - I know there have been links to the push ones, these:-
https://www.ebay.co.uk/itm/10x-8mm-Suzuki-Fairing-Shield-Trim-Cover-Clips-for-GSX-Bergman-V-Strom/371783087561?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649
and
https://www.ebay.co.uk/itm/10x-6mm-Plastic-Rivet-Bike-Fairing-Trim-Clips-Honda-Yamaha-Suzuki-Kawasaki/390578615411?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649
Which do the trick, however, I can find the screw-head ones, see pic - anyone know where you can get copy versions of those (trim on front of tank has two for instance).
Like the others, but have a Phillips screw head you turn to release.
Any links welcome.
Gert
Re: Trim Clips (again)
June 07, 2019, 07:25:47 »
Is this what you have in mind:-
https://www.ebay.co.uk/itm/Bossmobil-Vehicle-Body-Screw-Rivet-Fastener-Clip-Trim-Synthetic-15X10X7-mm/113669403024
https://www.ebay.co.uk/itm/10x-Motorcycle-6mm-Clips-Fairing-Plastic-Screw-Rivets-Panel-Trim-For-Suzuki/323138812713?_trkparms=aid%3D222007%26algo%3DSIM.MBE%26ao%3D2%26asc%3D20160323102634%26meid%3De560d5affb674a708b511cadb44be11c%26pid%3D100623%26rk%3D4%26rkt%3D6%26sd%3D371783087561%26itm%3D323138812713&_trksid=p2047675.c100623.m-1?
Not sure of the dimensions that you may require. There appear to be various other types advertised. Found these on doing a search on ebay, using the wording "motor vehicle trim rivets".
Fritz
Bike: DL650 K9
June 07, 2019, 09:42:50 »
They look pretty similar Gert, I'll try a more detailed search - just hoped someone maybe already had
Trim Clips (again)
