Author Topic: Noisy Bottom end?  (Read 924 times)
Offline Bedge
  • Bike: DL1000 2019, GSXR750 2015
Noisy Bottom end?
« on: June 04, 2019, 20:38:29 »
Hi All,
Pretty sure it's my naivety with big V twins after decades on in-line fours but.... :)
How lumpy at tick over should the DL1000 sound.?
It's a 2019 with about 800 miles now but starting to sound a bit noisy almost like it needs the injectors balanced (sounds little like a poorly balanced in line 4).. It may be my imagination but seems to be louder than when new so may just be loosening after getting a few miles under it's belt.
Pulling clutch in makes no difference apart from not hearing clutch type stuff :) as you would expect.
All smooths out above 2000 RPM and is running fine otherwise. I'll keep riding as its not enough to make me really concerned and it's under warranty anyway..
Any thoughts.. happy to have the p**s taken for being dim if they are just like that.....
Cheers,
Bedge....
Offline Joe Rocket
Re: Noisy Bottom end?
« Reply #1 on: June 04, 2019, 20:43:32 »
Is it ticking over at correct rpm? Straight fours or V-twins will be 'lumpy' if too slow......  :shrug:
Also, new bike, got to get used to it.......
Just a thought.
« Reply #2 on: June 04, 2019, 21:25:23 »
I thought this was about my wife!
Offline SimonW
  • Bike: DL1050XT
« Reply #3 on: June 04, 2019, 21:35:38 »
I vote idle hammer.
« Reply #4 on: June 05, 2019, 09:50:55 »
They all do that sir!   If you think it's bad now wait till your near 30k like mine!  Some do have idle hammer,  Like a knocking noise at tick over, mine doesn't.  The clutch will become worse the more miles  you out on it but nothing to worry about, just ride it.
