Author Topic: Houston I have a problem  (Read 1715 times)
Offline romeo one
« on: May 30, 2019, 23:48:53 »
I had some new tyres put on 12 month ago,( v strom 1000 2014 ) after three months I kept losing  pressure in the front checked it to find it leaking around the rim, I went back to the tyre fitter and he took the tyre off the wheel to find bad corrosion, he cleaned it up and painted some stuff on and said it would be OK, six month later it’s pi$$ing out around the rim, my question is could I get it powder coated or is it a new wheel ? I think he must have scraped it on removal and fitting and used fairy liquid solution which has salt in it to help with the fitting.
Offline Mr Nick
Re: Houston I have a problem
« Reply #1 on: May 31, 2019, 00:35:10 »
I've powdercoated the wheels on both of my Guzzis: better long term solution, but I think you could do with a better fitter...
Orange Bikes Matter!
Offline Skiddy
  • Bike: Suzuki DL1000 L5 Harley Davidson XR1200 BMW R1100S
« Reply #2 on: May 31, 2019, 06:17:00 »
Did you see the extent of the corrosion? Its unusual on a Suzuki rim of that age.
I would take it somewhere else and get them to remove and inspect the tyre and check that it has no damage around the bead.
If the tyre is OK and the wheel is infact corroded to the extent it won't hold air then powder coating would be my choice. I would do both wheels a nice colour and don't forget to factor in new wheel bearings.
« Reply #3 on: May 31, 2019, 09:52:44 »
... but I think you could do with a better fitter...
Absolutely! Its probable that he fecked up the original tyre change. How many miles had you done with no problems prior to that, I wonder?
« Reply #4 on: May 31, 2019, 10:43:56 »
What tyres?
I've used Heidenau K60 scouts on a few of my bikes and they always have a bead leak.
The sealing surface isn't great on some tyres.
I've since put on Mitas e-07 Dakars and they sealed fine on the same rim with not cleaning or painting.
But I'd also say it may be the fitter.
Puncturesafe stuff does also eat away at the inside of the rim, even the stuff that says it won't.
« Reply #5 on: May 31, 2019, 10:45:56 »
If the fitter had buggered your wheel you would have had a flat tyre that day or the next morning.
If a tyre machine and proper levers were used there is no way you can damage the surface the tyre seals against.
I'm going for corrosion .
Offline Andy52
  • Bike: Suzuki DL650 (2006), Honda PC800 (1989)
« Reply #6 on: June 01, 2019, 22:53:25 »
I had a similar problem with the alloy front wheel of my ancient Honda. I was advised to clean up the corrosion and use rattle-can lacquer on the rim. Over 3 years later it's still air-tight.
« Reply #7 on: June 02, 2019, 10:20:05 »
 :text-goodpost:   come to think of it, I did the same years ago on my old vauxhall cavalier
Offline oslin
  • Bike: DL650A L5
« Reply #8 on: June 02, 2019, 15:51:11 »
you are defiantly going to have to check the seal condition on the rim and the tyre to see if there any bits stuck on or missing from the tyre seal edge
Offline romeo one
« Reply #9 on: June 08, 2019, 15:06:31 »
Thanks for all your input blokes.
Offline hookie
« Reply #10 on: June 08, 2019, 18:22:13 »
All good and competent tyre fitters should check the sealing areas especially on alloy rims and clean up or make good any places where poor sealing is likely to occur. Using water based tyre fitting lube invariably makes things worse. If it's happening on a relatively new bike it may point to poor or inadequate paint finishing during manufacture. If corrosion is a problem then properly cleaning it off then using a proper metal etching primer before final painting should help as well.
Offline romeo one
« Reply #11 on: June 09, 2019, 11:48:48 »
I’m having the wheel powder coated and the spot light brackets as they’ve been rusting since day one.
