Author Topic: Setting the Odometer?  (Read 991 times)
Offline jjbrunton
« on: May 23, 2019, 13:51:22 »
So my last post was an issue with the dashboard on my Vstrom 650 ABS.. Short and sweet of it was that the dashboard had failed due to corrosion (the connector on the back had come clean off)..
I have replaced it with a brand new one but unfortunately that has set the mileage to 0.
Luckily I've tracked my miles in an app since my MOT and I'm fairly sure I can be accurate within 20 miles or so. The question is, how do I set the mileage on the dashboard?
Offline Holmsey
  • Bike: DL650 L9
Re: Setting the Odometer?
« Reply #1 on: May 23, 2019, 13:53:43 »
When I had the clock changed in mine .... I just wrote the mileage in the service book.
IBA Member
RBLR 1000 - 2018 -2019
Armistice 1000 - 2018
Offline jjbrunton
« Reply #2 on: May 23, 2019, 14:12:18 »
And left the bike odometer at an invalid count?
« Reply #3 on: May 23, 2019, 15:49:34 »
You can't ,  Only the trip meters can be reset .
Offline oslin
  • Bike: DL650A L5
« Reply #4 on: May 23, 2019, 16:51:38 »
As has been said  just make a note in the service book somewhere obvious perhaps in red and sign it, so there is no question of fraud when you come to sell it, I had to do that with an Aprilia I sold for the same reason.
Offline haydn
  • Bike: DL650 L3
« Reply #5 on: May 30, 2019, 19:34:35 »
Yeah, what he says.
I did the same in a Suzuki Swift after its clocks spontaneously combusted!
Online Rusty Nuts
« Reply #6 on: May 30, 2019, 20:12:14 »
There are lots of ads offering what is coyly referred to as "mileage correction" around here. If an odo was corrected to the actual mileage of the vehicle, is the simple act of changing an odometer reading from wrong to right still just a flat legal no-no?
