Author Topic: Clutch slave cylinder repair Vee K7  (Read 1051 times)
Offline 1monkey1
« on: May 05, 2019, 20:27:18 »
Evening all
Has anyone used  the slave cylinder repair kit
I got the one for the k7
It has a rubber washer
I presume it goes over the push rod
When I took off the slave cylinder. It has no rubber washer,
What it has
 l can describe it a rubber cone
Between the cylinder and the casing
Is the washer a replacement for the cone
If you look at the parts diagram it shows the washer but no cone
Any help much appreciated
When everything is coming your way, you're in the wrong lane.
Re: Clutch slave cylinder repair Vee K7
« Reply #1 on: May 06, 2019, 07:23:18 »
Looking at section marked #23 in the pix, from https://www.cheapcycleparts.com/oemparts/a/suz/506b2be1f8700231bc956367/clutch, the part that is not numbered (in between part # 28 and #24), could this be the cone that you are trying to identify?
« Reply #2 on: May 06, 2019, 08:31:38 »
If you are referring to part number 35, it's a separate part.
It just pushes on the pushrod before you fit slave cylinder. I believe its just a type of cover of some sort.
Offline 1monkey1
« Reply #3 on: May 06, 2019, 13:08:29 »
Sorry I can't work out how to post a link
Been ages since I have posted!
You get parts numbers 27,25,24 and posabley 35
On the parts diagram I have it dose not show number 28
That is where the confusion has arisen
Apparently you have to order part 28 separately
Thanks for your Replies
