Author Topic: Front sprocket  (Read 1102 times)
Offline Maddog123
  • Bike: DL650 L0, Triumph Speed Twin
Front sprocket
« on: April 27, 2019, 22:34:08 »
I have a 2010 650 what size sprocket is best , I’m not bothered about top speed .
Re: Front sprocket
« Reply #1 on: April 27, 2019, 22:44:33 »
The standard one that Suzuki recommend. Adjusting gear ratios will make your Speedo highly inaccurate.
Offline hookie
Re: Front sprocket
« Reply #2 on: April 27, 2019, 23:23:35 »
Not sure about all the DL650s but the early ones used a wheel speedo sensor, so changing the sprockets wouldn't make any difference to the reading. Later models may well be different. All DL1000s use a sensor from the gearbox so changing sprockets does alter the speedo reading, making it inaccurate. A smaller gearbox sprocket lowers the gearing, improving acceleration and increases engine revs at cruising speeds that you may not like. A bigger sprocket does the opposite, raises the gearing, reduces acceleration but can make cruising speeds more relaxing. Really depends what you are looking for. Generally speaking, standard gearing is best for most people.
Offline bosnjo
  • Bike: DL1000 L7
Re: Front sprocket
« Reply #3 on: April 28, 2019, 16:04:09 »
DL1000 use wheel sensor for speedo. I owned '14 model and now I own '18 model. I changed front sprocket on both bikes (went down one tooth) and there was no change on speedo.
DL1000 2017 white
DL1000 2014 red (sold)
DL650 2012 white (sold)
Offline Maddog123
Re: Front sprocket
« Reply #4 on: April 28, 2019, 18:16:47 »
Thanks for the info just what I needed
Offline DesertStrom
  • Bike: DL650 K9, Triumph Street Scrambler
Re: Front sprocket
« Reply #5 on: April 28, 2019, 18:53:20 »
I have tried standard, +1 tooth & +2 teeth.
Each increase of 1 tooth dropped the revs 500rpm ish when cruising at 80mph (on the continent of course!  :grin:) but when you get back to the twisty bit you can't beat the standard sprocket.  :thumb:
Offline hookie
Re: Front sprocket
« Reply #6 on: April 28, 2019, 20:06:12 »
All the first generation DL1000s (up to the K8s in the UK when they were off the market for a while) used a gearbox sensor and if sprockets were altered the speedo would need an additional device to correct it. The new generation 1000s have ABS which uses front and rear wheel speed sensors so there would be no need for the gearbox one. There was no ABS option on the early 1000s.
