have had this happen a couple of times when pulling away from juctions etc in first and find I can't change up to second, the gear lever seems stuck, end up having to pull the clutch in and out in a few times and eventually it will shift, then be fine for quite a while then do it again, bit one nerving when trying to accelerate away and you can't , only happens in first, any thoughts
