Author Topic: Clutch not disengaging  (Read 747 times)
Offline skatrekker
« on: April 24, 2019, 17:47:46 »
Last week rode my DL1000 K2 for about 30 miles, no problems , running well etc. Today I can start it no problem but clutch will not free up when engaging 1st or 2nd gear. I have bled clutch line until clear of air , plenty of line pressure, checked the slave cylinder is moving freely. Tomorrow I will remove the front sproket and clean out all the crap etc and check the push rods but after that I don't know what else it could b be. Any Ideas my fellow Strommers ?
Re: Clutch not disengaging
« Reply #1 on: April 24, 2019, 19:00:40 »
Could be a push rod issue as the position is directly in front of the front sprocket .
Offline skatrekker
« Reply #2 on: April 26, 2019, 23:37:27 »
Cable tied the clutch lever overnight and found it now works perfectly so the plates must have stuck together with the oil . Have now ridden on two days, lots of stops, engine off still no issues
