Author Topic: unidentified oil leak  (Read 3475 times)
Offline WeeStromer
  • Bike: DL650 AL2 GLEE, CG125 ES5
Re: unidentified oil leak
« Reply #20 on: November 16, 2020, 10:01:55 »
That's certainly worth looking at. I'm stripping my beauty to service it, valves, filters etc so I'll look over the bolts. Will report back once done.
Offline martind
  • Bike: DL650GT L3
« Reply #21 on: November 16, 2020, 18:08:43 »
If the oil is on the upper level you have over filed it. :thumb:
Eh? That’s where I fill up to :shrug: what’s the correct way then?
« Reply #22 on: November 16, 2020, 18:17:42 »
I'm with martind. Flat level ground, bike vertical, not on any stand, oil to upper level mark. That's full, not over full.
Offline STORMY
  • Bike: Triumph 1200 GT Pro
« Reply #23 on: November 17, 2020, 22:08:35 »
Upper mark, level ground equates to 3.1 litres with a filter change, just an oil change 2.7 litres according to the handbook = just on the high mark.
Never had any problems (1000).
The only slight problem I experienced was a slight weep from the oil pour hole, just needed a clean and that solved it.
The lack of sealant causing OP leak does sound a bit troubling however
