Author Topic: v strom 1000 rear shock  (Read 763 times)
Offline sidbig
  • Bike: DL1000 L8
« on: March 27, 2019, 17:15:00 »
Hi all just after a bit of help in to setting the read shock up for riding with top box and panniers on a tour what adjustment will I need to make any help taken never been fully kitted up before
Offline Downunder
  • Bike: Vee2
Re: v strom 1000 rear shock
« Reply #1 on: March 27, 2019, 23:24:09 »
I recently took a long trip on my DL1000A with the panniers and top case on and they were filled with stuff. I put 4 more clicks on the rear shock preload over my usual setting without the luggage cases. Initially it was just a guess, but worked out perfect for my trip. Set up is a personal thing. If I were you, after loading up the bike I would try riding a short distance without changing the rear preload to get a sense of how the bike is handling the load. Then adding a few clicks at a time, see how it feels and keep adding clicks until the bike handles and rides much the same as it does without any load.
Richmond, NSW, Aus
DL1000 ABS 2014
