Author Topic: horn problems  (Read 2709 times)
Offline trip67
  • Bike: Suzuki DL650 V-Strom
horn problems
« on: January 05, 2019, 19:08:36 »
My horn has become very muted and sometimes doesn't work at all. How would I go about repairing this?
Re: horn problems
« Reply #1 on: January 05, 2019, 19:29:53 »
Replace it with something like a Stebeil (sp?) Nautilus Compact. The compact version doesn't need a relay or additional wiring and it may even save your life  :thumb:
Offline wurzel
Re: horn problems
« Reply #2 on: January 05, 2019, 20:03:52 »
As Fat Rat says, you could also check your connections, make sure they are all good.
Offline user650
Re: horn problems
« Reply #3 on: January 05, 2019, 20:52:52 »
Mine had to be replace on my last Vstrom, it had corroded and was slightly damp inside so sounded a bit lame  :fix:
If It Starts Ride It
Posh Paul
IBA Member
RBLR 1000 '18
Armistice 1000 '18
RBLR 1000 '19
RBLR 1000 '22
RBLR 1000 '23
RBLR 1000 '24
Re: horn problems
« Reply #4 on: January 05, 2019, 23:48:31 »
The stock horns on most bikes are a bit feeble. I had a Denali Soundbomb for about 6 months on my Strom. Great when first installed but it quickly became unreliable. I replaced it with a pair of loud twin tone horns. I was pleased enough with them that I have now fitted a pair of the same type to my Super Tenere. A great improvement in sound over the standard offering.
Offline sillyboy
  • Bike: DL650 L7
Re: horn problems
« Reply #5 on: January 06, 2019, 17:37:31 »
mine is the same, old age and due to high blood pressure can't use viagra. :grin:
Offline sillyboy
  • Bike: DL650 L7
Re: horn problems
« Reply #6 on: January 06, 2019, 17:39:29 »
I was replying to the op's post. not just my horn which isn't working. :groan:
Re: horn problems
« Reply #7 on: January 06, 2019, 19:20:11 »
 :haha:
Offline BigAldo
  • Bike: DL650A L4
Re: horn problems
« Reply #8 on: January 07, 2019, 22:45:36 »
+1 on TallPaul's Ebay horns, although I've wired mine through a relay.
Cheap & loud.
As in LOUD
Re: horn problems
« Reply #9 on: January 07, 2019, 23:15:21 »
I have the same as tallpaul and also wired through a relay. They're great at getting you noticed in situations where the stock horn would have been useless.
I've had two Stebel Nautilus air horns in the past, and whilst nice and loud, they both gave up after a couple of years.
Offline wurzel
Re: horn problems
« Reply #10 on: January 07, 2019, 23:15:46 »
 Sillyboy,  apply vinegar and rub it vigorously with the sporting life paper, it works a bit like smelling salts.
Report back how you get on....... :eusa-doh:
Re: horn problems
« Reply #11 on: January 08, 2019, 06:37:08 »
Yes, I too wired my eBay horns through a relay.
Offline sillyboy
  • Bike: DL650 L7
Re: horn problems
« Reply #12 on: January 08, 2019, 12:51:38 »
Quote removed
silly boy by name not by nature. :grin:
Re: horn problems
« Reply #13 on: January 08, 2019, 18:16:38 »
trip69, have a look at this link how to beef up your bike horn, fit a relay etc :thumb:
https://www.v-strom.co.uk/smf/index.php?topic=21326.0
wurzel, I took your advice and now my stroms horn just burbles pathetically, nowt comes out. :GRR: Was I just supposed to rub the wires?, or maybe I rubbed too hard
Re: horn problems
« Reply #14 on: January 08, 2019, 18:22:01 »
Is balsamic vinegar OK, or chip shop standard?
