Author Topic: car wheels query  (Read 1064 times)
car wheels query
« on: December 29, 2018, 14:07:25 »
My Fiat Doblo passed it's MOT recently with the comment that one of the wheels was a little out of true.  Probably pot hole damage, I thought it needed a wheel weight as on the move it vibrates a bit.
It's an alloy wheel and I can take it to a wheel straightening garage.
However when I pulled the spare wheel out I  found it to be corroded beyond repair and the tyre side wall splitting.
I have found steel wheels on Ebay at a reasonable price so should I replace the two rear wheels with steel jobs and keep one of the alloys as a spare? or replace the spare wheel and get the damage wheeled trued?
Given the state of the roads around here I wonder if Alloy wheels can cope as wheel as steel wheels?
Offline TLPower
Re: car wheels query
« Reply #1 on: December 29, 2018, 16:36:18 »
I'd go for the steel wheel option. Either a full set or your idea of just the 2 and an alloy spare. Bare in mind that you may need different wheel bolts as the alloy wheels will have a thicker boss.
My ancient Volvo has alloys, they are quite robust but became porous around the bead seal. I had the last tyres fitted by Halfords and they managed to clean up and seal where two other tyre fitting companies couldn't.
Trueing wouldn't be my preferred solution ever.
