Author Topic: Radiator for 2013 glee  (Read 1088 times)
Offline Winder
  • Bike: DL650 L3
« on: December 23, 2018, 17:04:01 »
Got a stone fly up and smash my rad. Coolant dumped everywhere. I have been looking for second hand strom rads and Suzuki Gladius rads but nothing comes up.
Does anybody know where I can get hold of an aftermarket rad that will have similar mounting points or is anyone breaking a vstrom?
Mark
Re: Radiator for 2013 glee
« Reply #1 on: December 23, 2018, 18:47:18 »
Sorry to hear that, a lot of us fit rad guards to avoid the £600 cost of a replacement.
The SV/Gladius rad will not fit - the DL rad is specific to the the model bike you have.
The k4-L1 rads will not fit, neither will the Current model or the ones for either model DL1000 (going by your avatar)
There are places that will repair rads - but you'll need to search local to you- should come in a fair bit cheaper than new replacement.
The part you are looking for is 17710-11J00-000 (rad alone - using all existing mounts, cap and bolts)
Offline mrp192
  • Bike: V-Strom 1050
« Reply #2 on: December 23, 2018, 19:07:02 »
This is very out of date but many years ago I had the same problem with a 350 Powervalve. I looked around for a repair and found a bloke in Bagshot, Surrey that wrote it off as unrepairable, but then actually built me a new radiator for under half the price of the Yamaha part.
I should think that fella is long retired but presumably the idea may still hold some water :thumb:.
Perhaps a look through the MCN classifieds might find you someone.
« Reply #3 on: December 23, 2018, 20:03:15 »
A quick Google turns a few possible repairers up.
one of them..............http://readyrads.co.uk/motorbike-radiators/
« Reply #4 on: December 23, 2018, 20:35:21 »
Here is another.
Offline Winder
  • Bike: DL650 L3
« Reply #5 on: December 26, 2018, 09:54:44 »
Thanks blokes. I have removed it and think I might be able to just pinch closed the broken coolant lines and weld them shut. Means the rad has lost about 25% flow of coolant but in the UK the hottest it ever gets is 35 degrees so I guess it'll work. I will call up some local repair places and get a quote too. cheers
