Having a tech' clear out hence this sale, and others! This got a Ride magazine Best Buy triangle when tested against other intercom units which speaks volumes IMHO. Fab' condition, great battery life and some bits still unused, it's really not had much use! The helmet 3M tape attached support bracket is unused so you can stick the unit to your lid if you want to. There is the option to use a support bracket which is placed up inside the helmet lining if you don't want to stick the 3M bracket to your lid. Range is good and online reviews are supportive of the unit's performance. Check out the reviews at Sportsbikeshop as well. Another advantage of this unit is its Anycom function which allows it to talk to other third party intercoms. Built-in FM radio too
(Hopefully pics attached!)
Price including postage ?75
Tech' burb below!
The Interphone F5MC is a Bluetooth device with some of the most functionality on the market for
Motorcycle communications and entertainment. The F5MC allows full-duplex conference communication between up to four riders at a distance of Up to 1.3 kilometres. It lets you connect to a smartphone for listening to music in stereo via A2DP and allows you to use the Cellular functions available and to listen to FM radio with RDS directly from the F5MC device. You can also connect it to an iPod or MP3 player using a cable reducing the loading on the F5MC's battery. Thanks to the Anycom function the rider is able to connect to other riders within a group who are using Third party intercoms and thanks to the Song Sharing function a rider can share music with another rider thus making travelling even more enjoyable. Multi-language TTS voice guidance makes the F5MC a device that is easy to use even for those motorcyclists who are less inclined towards more technologically sophisticated products. It can also receive audible directions from a motorcycle Bluetooth GPS navigator. The unit is IP67 certified against dust and water ingress and enabled for both the A2DP and AVRCT communications protocols. It can easily be installed into any type of jet, modular or integral helmet.
Rechargeable Li-Polymer battery
Talk time up to 12 hours
Standby time 700 hours
Charging time 3 hours
Digital Signal Processing (DSP) for advanced audio filtering and wind noise suppression
Backward compatible with Interphone headsets (reduced operational range when connected to earlier models)
Intercom up to 1.3 km in full duplex
4-way conference mode, 4 different bikes or 2 bikes rider + passenger
3-way 3 separate bikers
2-way rider-to-rider or rider-to-passenger
Auto-reconnection if communication lost
Mobile phone headset and handsfree profiles
A2DP/AVRCP profile for wireless streaming stereo from MP3 player or other A2DP device
Voice dial
Redial
Call reject
Last number redial
Built-in FM radio, 88.0mhz to 108mhz FM receiver
RDS functionality (adjusts to best frequencies according to zones)
8 preset station memory with Search and Store function
Automatic radio muting for incoming calls
GPS (Headset profile required) compatible with most major SatNavs for motorcycles
GPS voice instructions
Wireless MP3 music (A2DP) or through cable connected MP3 player
Music sharing
Firmware update-ready directly from PC (Windows)
Fits any type of helmet
Quick release system to detach device from clamp
Double mounting bracket (clip and adhesive)
Two slim speakers to fit even tight helmet
Multi function button (MFB)
Waterproof IP67 approved (completely protected against the effects of temporary immersion and dust)
Interphone Remote Control compatible
TTS ? (Text To Speech) Multi-lingual spoken status announcements
Noise cancellation microphone
AGC Technology - Automatic volume adjustment
Two way setting volume a) for jet helmets b) for full face helmets
Bluetooth Version 3.0
Double USB cable
Weight 55gr, length 9cm, height 4.5cm, depth 2cm
Certified CE, FCC, IC, Bluetooth
