Author Topic: risers on a late 2015 v-strom  (Read 1223 times)
Offline oslin
  • Bike: DL650A L5
« on: November 30, 2018, 14:20:35 »
Hello all I have read all the posts on fitting 25mm risers to my late 2015 v-strom everyone says they will fit but I have a problem with the throttle cables being too short, if I could lower the cables where they exit the throttle grip I might be able to manage it but the hand guard and its location bolt is in the way has anybody found a solution to this perhaps a mod to the hand guard ? if anyone has perhaps they could tell me how they got over it please.
Keith
Offline bako
  • Bike: DL1000A L6
Re: risers on a late 2015 v-strom
« Reply #1 on: November 30, 2018, 16:38:16 »
I had 25mm risers on my 2017 vee. Cables are a little tight but managable. Suzuki don't give you much play in any of the cables or hoses, but I did manage to get a little extra from where they all disappear under the tank.
Offline Dave L
  • The older I get the faster I was......
  • Bike: DL650 AM3
« Reply #2 on: November 30, 2018, 17:16:21 »
Hello,
I have a 65 plate 650 V Strom and have inserted 25mm risers with no issues.
Offline oslin
  • Bike: DL650A L5
« Reply #3 on: November 30, 2018, 22:30:08 »
Thanks blokes and for the photos But my throttle cables have no play at all on full lock so I guess I will have to do as suggested and have a look under the tank to see if there is any slack under there
Offline oslin
  • Bike: DL650A L5
« Reply #4 on: December 01, 2018, 14:09:31 »
Hi Bako, are the throttle cables clamped /fixed to the frame under the tank ?
Offline oslin
  • Bike: DL650A L5
« Reply #5 on: December 05, 2018, 12:59:06 »
Hello All, does anybody know if the throttle cables on a late 2015 650 V-strom are tied or fixed to the frame under the tank ? I do not want to take the tank off unless I have to, to install 25mm risers, my throttle cables have 3mm slack on full lock.
Keith.
