Author Topic: Captive exhaust mount nut.  (Read 1774 times)
Offline Cymro
  • Bike: KLV1000 ('05)
« on: October 30, 2018, 22:33:11 »
Spinning like a good one.  ###
Anyone had this problem ?
Offline Cymro
Re: Captive exhaust mount nut.
« Reply #1 on: November 02, 2018, 12:21:27 »
No worries. All sorted.
Drilled a hole to weaken the nut 'casing' and chiselled it loose with an old flat blade driver, then a disc cutter to remove the bolt head at the other end and tapped it through.
A slightly longer replacement bolt was supplied with the Cosmo skid plate I was fitting.
« Reply #2 on: November 02, 2018, 16:20:27 »
Well done!  :fix:
