Removing front wheel
Topic: Removing front wheel (Read 1272 times)
Metro Strommer
Bike: V Strom 650
October 22, 2018, 10:44:24 »
How do other members get the
ir
bike up to remove front wheel I've got a centre stand and front and rear paddock stand getting the back end up is no problem but the front with the bigger wheel my front one does not get the front up am I missing something or is it safe to jack the bike up a little with a bottle jack ??
SuzukiSte
Re: Removing front wheel
October 22, 2018, 11:06:24 »
Use a head stock padock stand or Jack and wood chok under the engine.
Gassoon
Quotes Museum Curator & Moderator
Bike: DL650X L7
October 22, 2018, 12:53:46 »
Load up your topbox with bricks!
Or, the sensible way, as above
But seriously, an additional (stable) weight on the rear rack is a decent backup, in case a jack gets nudged in the process
Brockett
Bike: 2022 Moto Guzzi 850 V7 special in blue, 2022 850 V7 Stone in darkest black, 1998 XJ600n in red. 2021 Royal Enfield 500 Classic stealth.
October 22, 2018, 17:28:46 »
You can use a bottle or other jack as long as you tie the bike so it cannot fall over sideways. Make sure the jack is not lifting the oil filter or something similarly fragile.
UK_Vstrom650
Bike: DL650A L2
October 22, 2018, 23:58:21 »
As above, centre stand and jack under the engine. It also helps to put the centre stand on 25mm wood to help give extra clearance for the front mudguard. Also if you're leaving the bike jacked up you may wish to support the bike with an axle stand (I use one with some wood to the crashbars)
Gert
Reply #5 on:
October 23, 2018, 07:35:39 »
http://www.vstrom.info/vsri-gallery/gallery/MM/CHASSIS/Fork+Seal+lift.jpg.html
Mr Nick
Certified Fisher Price trained technician
Bike: 1979 Suzuki TS185ER, 1979 Moto Guzzi V50, 1989 Moto Guzzi SP3, 2010 KTM 990 Adv
Reply #6 on:
October 23, 2018, 21:32:24 »
Or just install an electric winch in your garage rafters:
Maybe a bit much for the occasional wheel removal....
Orange Bikes Matter!
Andy52
Bike: Suzuki DL650 (2006), Honda PC800 (1989)
Reply #7 on:
October 25, 2018, 22:30:14 »
Bricks under the front stand.
