Author Topic: Helmet camera shark evo 3  (Read 3396 times)
Offline Zed 25
  • Bike: Triumph Tiger 900 GT
« on: October 05, 2018, 18:54:24 »
Hi
Looking for some help please
Does anyone have a helmet camera fitted to flip up
I have a shark evo 3 ,wanting a camera for day to day commute
( constant loop) but not sure how or where to fit
Other option is bike mounted (2017 650 v strom)
Re: Helmet camera shark evo 3
« Reply #1 on: October 05, 2018, 21:03:38 »
I mounted my old mobius camera to the right side of my helmet using the adhesive mount, which worked well until it died (not waterproof). Have since moved my camera to the throttle side crashbars. It's wired to record with the ignition.
Offline Zed 25
« Reply #2 on: October 05, 2018, 21:26:45 »
Thanks
V strom 650
What make are you using now and how did you attach it to the crash bar?( Ihave sw motech ones)
Offline user650
« Reply #3 on: October 05, 2018, 21:32:55 »
I have mine permanently mounted on the left mirror mount, works well as a dash cam. I've got some footage if you want an idea of the view you get.
If It Starts Ride It
Posh Paul
IBA Member
RBLR 1000 '18
Armistice 1000 '18
RBLR 1000 '19
RBLR 1000 '22
RBLR 1000 '23
RBLR 1000 '24
Offline Zed 25
« Reply #4 on: October 05, 2018, 22:12:51 »
Thanks user650
Who’s camera and mount are you using?
I see you’ve got mirror extenders like me ,is the mount fixed to the
Handle bar or the mirror extender bolt?
Offline user650
« Reply #5 on: October 06, 2018, 02:56:21 »
Hi Zed 25
The case and the camera are the GoPro Hero 3 with a ram mount ball fitted. The other end is mounted on the mirror mount not on the extender, connected with a short ram arm. I've also put my Sony AS50 on this mount as well but mainly use that on my helmet.
Posh Paul
IBA Member
RBLR 1000 '18
Armistice 1000 '18
RBLR 1000 '19
RBLR 1000 '22
RBLR 1000 '23
RBLR 1000 '24
« Reply #6 on: October 06, 2018, 09:03:09 »
I have a cheap GoPro knock off (SJ5000) which uses GoPro mounts. I've added a video of how it looks though following user650's video I might look at mounting it to the mirror at some point.
Offline Zed 25
« Reply #7 on: October 06, 2018, 09:42:30 »
Thanks both of you for help and great video
Think permanent fixed and wired to the bike is the way to go
 :thumb:
Offline Graham62
  • Bike: DL650 K6 Blue
« Reply #8 on: October 06, 2018, 13:18:08 »
I've got a sj9000 cheap gopro copy on a bracket on the left hand side mirror mount.
Graham
« Reply #9 on: October 06, 2018, 14:17:31 »
Looks good. Where did you get your mirror mounts from?
Offline Zed 25
« Reply #10 on: October 06, 2018, 17:39:01 »
Can these sj cameras be run off the bikes electrical system
( BP aux fuse box or plugged into oem 12v socket in fairing)
To switch on and off with ignition
« Reply #11 on: October 06, 2018, 19:59:03 »
Yes they can. Mine is wired via a usb cigarette socket to a Bigpie fuse box. The camera has a setting to turn on/off (dashcam) with the electrics.
Offline Zed 25
« Reply #12 on: October 06, 2018, 20:42:28 »
Thanks uk 650 :thumb:
Offline Graham62
« Reply #13 on: October 06, 2018, 20:43:52 »
@ UK_Vstrom650 I made the arm from some flat steel and bent it to shape the adjustable mount is a mount for a flash Adapter for a Camera.
@ Zed 25 as said above some but not all have the dashcam mode.
Graham
« Reply #14 on: October 06, 2018, 21:46:40 »
Cheers Graham62  :thumb:
Offline Graham62
« Reply #15 on: October 06, 2018, 22:05:13 »
The mirror extenders were from ebay.
Graham
Offline Zed 25
« Reply #16 on: October 07, 2018, 10:18:30 »
Where did you get your sj cameras from ?
Look on the flea bay is a minefield
prices £100 to £10
Need camera, waterproof case and mount ( most likely handle  / mirror ) need loop sj5000 has it but not sure about 9000
Decided  would like other options than just dash cam alone
« Reply #17 on: October 07, 2018, 12:07:32 »
There are fake SJCAMS out there, probably the reason for the cost difference.
Have a look at this........
https://pevly.com/sjcam-sj-scam-difference-real-fake-camera/
if you search you should find other information to help you decide how much of your hard earned you should part with.
Offline Graham62
« Reply #18 on: October 08, 2018, 22:06:20 »
As Mick said there are fake sjcams [mine included].
Ebay have some real Sjcam SJ4000 for £40
Graham
Offline Zed 25
« Reply #19 on: October 08, 2018, 23:30:01 »
Just like to thank everyone  for their help have got a sj 5000 with case and lots of bit just need to make a mount ,going try Graham 62 idea if he don’t mind, or just need to drill hole in side of case to put power cable in
  :ty:
