Stator and rotor
Topic: Stator and rotor (Read 1450 times)
tempo.175
Bike: DL-655 09, VFR 1200X 12, Tempo Swing175 57
Stator and rotor
September 29, 2018, 13:25:44 »
Hello
Can anyone here tell me if a stator and rotor from V-strom 650 07 model will fit a 09 model?
As you can see I need another :-)
Gert
Re: Stator and rotor
September 30, 2018, 07:13:35 »
If I remember correctly, yes, they both have the same stator output. The K4 - K6 Wee had a lower stator / wattage output. Just to make 100% certain, it would be best to check the listed part numbers for these two models (ie K7 vs K9).
Gert
September 30, 2018, 07:28:01 »
I've just confirmed that the stators are the same for the K7 / K7A / K8 / K9:
https://www.mrcycles.com/oemparts/c/suzuki_motorcycle/parts/
part number changed from 32101-17G10 to 32101-17G12 on both the K7 and K9
And if you wonder why the K7 & K7A, the K7 is without ABS while K7A has ABS.
Ianmc
Bike: DL650AL5
September 30, 2018, 12:30:05 »
Hello Temp,can I ask what happened to cause the damage? Was it internal or a road rash ?
tempo.175
September 30, 2018, 14:47:32 »
Hi Ianmc
it was oil spill on the road
Ianmc
Bike: DL650AL5
Reply #5 on:
September 30, 2018, 16:32:21 »
Ouch !
That’s bad luck.
tempo.175
Reply #6 on:
December 23, 2018, 04:48:06 »
The damage was more then just the stator and magnet.
The crank shaft has been bent
didn't chek that at once.
Anyone here have a spare engine for sale?
Ianmc
Bike: DL650AL5
Reply #7 on:
December 23, 2018, 09:35:41 »
That’s going to make a hole in your wallet. I am curious,do you have crash bars fitted ?
oslin
Bike: DL650A L5
Reply #8 on:
December 23, 2018, 12:04:03 »
its a search on ebay then, sorry to hear that.
I am a bit surprised I would of thought the cover would of taken the brunt of the accident
Stator and rotor
