wheel corrosion on 2014 V strom 1000
Topic: wheel corrosion on 2014 V strom 1000 (Read 1002 times)
romeo one
Bike: DL1000 L4
September 26, 2018, 19:31:23 »
I leave my bike at my daughters house in the UK as I live abroard now I last rode the bike in late June when I went back early Sept the front tyre was flat pumped it up checked it for punctures and then went in with the soapy water and brush , the leak was between the rim and the tyre, I took it to the tyre fitters, they pulled the tyre and the rim was quite badly corroded, just wondered has anyone else had a similar problem, second set of tyres,16000 miles on the bike.
Relevant11
Bike: Dl1000L4. KTM XCF 350, Royal Enfield interceptor 650( yes they are as good as they say)
Re: wheel corrosion on 2014 V strom 1000
September 26, 2018, 20:20:10 »
Does it live outside?
mr_diver
September 26, 2018, 20:23:20 »
It is a known problem with alu rims.
If the inside of the rim is scratched when putting the tyres on then they will quickly corrode.
Also most of the sealant like slime or puncturesafe will also corrode the rims.
Some tyres do not seat on the bead 100% either cause a leak or allows water to sit in the rim a d corrode.
romeo one
Bike: DL1000 L4
September 26, 2018, 20:45:30 »
Not outside, lives in a dry garage joined to the house.
The Border Riever
Bike: DL1000 AL9
September 26, 2018, 22:54:19 »
Puncture sealant can cause havock to alloy rims, did the tyre fitters find any evidence of the slime/foam present in the rim, if not it may have been used in the past?
doboy
Bike: 1050 v strom
Reply #5 on:
September 27, 2018, 08:39:36 »
They have the same problem of rotting spokes on the yamaha 1200 tenere . I've had two new one,s & no matter what I tried they both rotted like hell , and NO ..I didn't ride them in the winer so cannot blame road salt ..just poorly made .
romeo one
Bike: DL1000 L4
Reply #6 on:
September 27, 2018, 10:01:58 »
I have had the bike from new , the history is, I never ride in winter in the UK so no salt has been near the bike and never put anything in the tyres except air.
wurzel
Bike: DL1000 L4
Reply #7 on:
September 27, 2018, 10:45:44 »
Some soaps, like washing up liquid,contain salt, if not completely rinsed away they can get trapped and cause corosion.
Gassoon
Quotes Museum Curator & Moderator
Bike: DL650X L7
Reply #8 on:
September 27, 2018, 17:22:19 »
bad luck there, romeo1
. Maybe the cause was in the manufacturing or transporting of the wheel, or corrosion like wurzel says? It could also be by poor tyre changing - presumably its out of warranty, so just to be sure, I would never go back to that tyre changer again. Was it bike shop/garage?
romeo one
Bike: DL1000 L4
Reply #9 on:
September 28, 2018, 07:50:03 »
It was a well established tyre business.
