Author Topic: air presure  (Read 1149 times)
Offline EYAL400
  • Bike: bsa 500,vespa 150,mz 250,suzuki gsx 550,suzuki gsx 400,dl650.
air presure
« on: September 17, 2018, 15:08:55 »
how much presure you lose in the Tyres in one month ?
Ride safe .
Re: air presure
« Reply #1 on: September 17, 2018, 15:47:17 »
Very little. How much are you losing?
Offline EYAL400
Re: air presure
« Reply #2 on: September 17, 2018, 15:55:59 »
3 per month .
Ride safe .
Online UK_Vstrom650
Re: air presure
« Reply #3 on: September 17, 2018, 17:57:45 »
Are you talking PSI?
It depends on temperature etc.
Good to see you're checking them.
Offline EYAL400
Re: air presure
« Reply #4 on: September 17, 2018, 18:01:00 »
yes , 3 psi per month .
Ride safe .
Re: air presure
« Reply #5 on: September 17, 2018, 19:09:01 »
What tyre pressures are you using?
Offline EYAL400
Re: air presure
« Reply #6 on: September 17, 2018, 19:29:48 »
a good one , germany .
Ride safe .
Re: air presure
« Reply #7 on: September 17, 2018, 20:44:55 »
How much air in each tyre?
Offline EYAL400
Re: air presure
« Reply #8 on: September 17, 2018, 21:07:54 »
front 33 rear 36  psi .
Ride safe .
Offline Griff2
  • Bike: DL1000 L6
Re: air presure
« Reply #9 on: September 18, 2018, 11:53:33 »
A change in temperature will also affect tyre pressure. My Wife told me the other evening that the Tyre pressure light came on in the car. That coincided with a drop in temperature and sure enough all four tyres were down about 2/3 psi. On other occasions normal "seepage" will drop 2/3 psi but both aspects need to be taken into account.
On the other end of the scale my former GL1800 actually picked up pressure one year as I progressed south through Europe into hotter climes.
Offline bako
  • Bike: DL1000A L6
Re: air presure
« Reply #10 on: September 18, 2018, 12:40:24 »
Might be a leaky valve insert. Try loosening the stem let the eascaping air blow the crap out the re tighten, but not over tight. Re-set the pressure. little spit on your finger tip and wipe it across the end of the valve, if the film of spit stays in place all good. Any leak will push the spit off.
Offline pichulec
  • Bike: KTM 1290 SAS
Re: air presure
« Reply #11 on: September 18, 2018, 20:33:42 »
I am losing 0 psi per month. Check valves and tyres for slow puncture.
